GM27-CQS Gaming Monitor image number 0
GM27-CQS Gaming Monitor image number 1
GM27-CQS Gaming Monitor image number 2
GM27-CQS Gaming Monitor image number 3
GM27-CQS Gaming Monitor image number 4
GM27-CQS Gaming Monitor image number 5
GM27-CQS Gaming Monitor image number 6
GM27-CQS Gaming Monitor image number 7
GM27-CQS Gaming Monitor image number 8
GM27-CQS Gaming Monitor image number 9
GM27-CQS Gaming Monitor image number 10
GM27-CQS Gaming Monitor image number 11
GM27-CQS Gaming Monitor image number 12
Drive Into The Gaming World
The GM27-CQS can be adjusted by height, swivel, and tilt that empowers your work/play experience.
Comprar ahora
Especificaciones
  • Curve 1500R
  • I/O - Earphone Out 1
  • DisplayHDR400 Compatible
  • Anti-flicker Yes
  • Panel Type Curved Series
  • I/O - HDMI 2.0 2
  • Overdrive Technology Yes
  • VRR Technology FreeSync Range: Yes
  • Monitor Series GM Series
  • I/O - DP 1
  • Swivel Adjustment -15°~+15°
  • I/O - Speaker 2 (2W)
  • VESA 100x100 mm
  • Tilt Adjustment -5°~+20°
  • Ratio 16:9
  • Screen Size 27"
  • Height Adjustment 0-130 mm
  • VRR Technology G-Sync Range: Yes
  • Product Gaming Monitor
  • Note * Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Response Time 0.5ms
  • VRR Technology FreeSync Premium
  • Contrast Ratio 4000:1
  • Resolution 2K WQHD 2560x1440
  • Color Gamut DCI-P3 90% sRGB 120%
  • Brightness 350 nits
  • Panel Ultra-Speed VA 16.7M
  • Frame Rate 170 Hz (overclocking)
  • Power Consumption 15W*
  • Product Number CMI-GM27-CQS
