Elite 370
Elite 370
Color(s)Black
SizeMid Tower
LegacyCases
Cooling System - Side120/140mm fan x 2 (optional)
Cooling System - Top120mm fan x 2 (optional)
Cooling System - Bottom1x 80/90/120mm Fan (Optional)
Cooling System - Rear120mm fan x 1 (installed, 1200 RPM, 17 dBA)
I/O Panel2x USB 2.0
Expansion Slots7
SeriesElite Series
Power Supply SupportStandard ATX PS2 (optional)
Cooling System - Rearor 80/90mm fan x 1 (optional)
Gross Weight5.8 kg / 12.78 lbs
MaterialsSteel body
Maximum Compatibility - CPU Cooler Height163mm / 6.4 inch
Cooling System - Front120/140mm fan (optional)
5.25" Drive Bays3 (exposed)
Net Weight4.7 kg / 10.3 lbs
I/O Panel1x Mic
Maximum Compatibility - VGA Card Length315mm / 12.4 inch
MaterialsABS Plastic
3.5" Drive Bays1 (exposed)
I/O Panel1x Audio (supports HD audio)
3.5" Drive Bays5 (hidden)
Dimensions (L x W x H)190 x 424 x 481 mm / 7.5 x 16.7 x 18.9 inch
Model NumberRC-370-KKN1
