Dyn X Motion System image number 0
Dyn X Motion System image number 1
Dyn X Motion System image number 2
Dyn X Motion System image number 3
Dyn X Motion System image number 4
Dyn X Motion System image number 5
Dyn X Motion System
Dyn X Motion System
Dyn X Motion System
Dyn X Motion System
Dyn X Motion System
Dyn X Motion System
Dyn X Motion System
Introducing the Cooler Master Dyn X Motion System: a leap forward in motion simulation, designed for sim racing, and flight simulation enthusiasts and professionals.
Professional Motion System
Provides exceptionally realistic vehicle motion feedback.
DYN X ACTUATOR MOUNT FEATURES
Haptic Feedback
Broad Compatibility
Electronic Mounting Tray
Simple And Easy Installation
Responsive actuator travel
Features 2” (50mm) of possible travel.
Rugged Construction
A piston featuring an especially large diameter and a machined billet with aluminum housing have been built to last.
Large weight capacity
Supports up to 800 lbs. (363 kg).
Game Support
Racing
  1. Assetto Corsa
  2. Assetto Corsa Competizione
  3. Automobilista 2
  4. American Truck Simulator
  5. BeamNG.drive
  6. DiRT Rally 2.0
  7. EA Sports WRC
  8. Euro Truck Simulator 2
  9. F1 2021
  10. F1 2022
  11. F1 2023
  12. Forza Motorsport
  13. Forza Horizon 4
  14. Forza Horizon 5
  15. iRacing
  16. Kart Kraft
  17. Le Mans Ultimate
  18. Project CARS 2
  19. Project CARS 3
  20. RaceRoom Racing Experience
  21. rFactor 2
  22. Richard Burns Rally
  23. WRC Generations
Flight
  1. X-Plane 11
  2. X-Plane 12
  3. DCS World
  4. Microsoft Flight Simulator 2020
  • Actuator Travel 2" (50mm)
  • Actuator Speed 7.93"/s @ 2380 rpm
  • Actuator Piston Diameter 2" (50mm)
  • Actuator Housing Material Machined billet aluminum
  • Actuator Servo Motor ClearPath
  • Actuator Servo Motor Rated (RMS) Torque 209 oz-in (1.5 Nm)
  • Actuator Servo Motor Peak Torque 698 oz-in (4.9 Nm)
  • Actuator Servo Motor Max Speed 2,380 rpm
  • Actuator Total Weight Capacity 800 lb (363 kg) / 4-actuator system (for optimal performance, including fully-loaded simulator with driver)
  • Actuator Power Consumption 330 W/h at 110V
  • Controller Box Input (switchable voltage) Voltage 95-125/190-250 VAC; 50-60Hz
  • Controller Box Dimension (W x D x H) 38.1cm x 23.5cm x 7.6cm (15“x9.25“x3“)
