USP 100 Black (Asia only)
Color(s)Black
SizeMid Tower
LegacyCases
Cooling System - Bottom1x 80/90/120mm Fan (Optional)
Cooling System - Rear80/90/120mm fan x 1 (optional)
I/O Panel2x USB 2.0
Expansion Slots7
Power Supply SupportStandard ATX PS2 (optional)
MaterialsSteel body
SeriesOthers
Maximum Compatibility - VGA Card Length290mm / 11.417 inch
Color(s)Red
Maximum Compatibility - CPU Cooler Height170mm / 6.69 inch
MaterialsMesh and Plastic
3.5" Drive Bays6 (hidden)
I/O Panel1x Mic
I/O Panel1x Audio (supports HD audio)
5.25" Drive Bays4 (exposed)
3.5" Drive Bays1 (exposed)
Net Weight7.2kg / 15.87lbs
Cooling System - Front120 x 25 mm Blue or Red LED fan x 1 / 1200 RPM / 19 dBA
Dimensions (L x W x H)214 x 483 x 508 mm / 8.43 x 19.02 x 20 inch
Model NumberRC-P100K
