MasterAir Pro 3
The MasterAir Pro 3 is the new design in air cooling from Cooler Master.
Cooler TypeAir Cooler
Warranty2 years
Fan Power Connector4-Pin (PWM)
CPU SocketLGA2066
Fan Safety Current0.2A
Heatpipes3
CPU SocketLGA2011-v3
CPU SocketLGA2011
Fan L-10 Life50,000 Hours
Fan MTTF350,000 Hours
Fan Rated Current0.1A
Fan Dimensions (L x W x H)92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
CPU SocketLGA1366
Fan Power Consumption1.2W
CPU SocketLGA1200
CPU SocketLGA1156
CPU SocketLGA1155
CPU SocketLGA1151
Heat Sink Material3 Heat Pipes
CPU SocketLGA1150
CPU SocketLGA775
Heat Sink MaterialAluminum Fins
CPU SocketAM4
CPU SocketAM3+
Heat Sink MaterialCDC 2.0
Fan Airflow28 CFM (Max)
CPU SocketAM3
CPU SocketAM2+
CPU SocketAM2
Heat Sink Dimensions (L x W x H)61.5 x 108 x 140 mm
CPU SocketFM2+
CPU SocketFM2
CPU SocketFM1
Heat Sink Weight390g
Fan Speed650-3000 RPM (PWM) ± 10%
Fan Air Pressure2.5 mmH2O (Max)
Dimensions (L x W x H)78 x 117 x 140 mm
Product NumberMAY-T3PN-930PK-R1
