Faça dele o que quiser!
Vertical Graphics Card Holder Kit
Kit de suporte vertical para placa de vídeo
Especificações
Capacidade da placa de vídeoOne graphics card per holder
RequisitoRequires seven PCI case slots
Modelo do cabo riserRiser Cable PCIe 3.0
SuportePCI area of your Case
Peso líquido0.230Kg
Cor(es)Dark Metallic Grey
LegacyAccessories
NotaThis product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
