SickleFlow 120 image number 0
SickleFlow 120 image number 1
SickleFlow 120 image number 2
SickleFlow 120
SickleFlow 120
SickleFlow 120
Escolha o máximo
SickleFlow 120
The new SickleFlow 120 fan blades were created with larger blades and increased curvature to optimize the air flow and air pressure performance...
SickleFlow 120, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
Sealed Bearing Structure
Especificações
  • Modelo MFX-B2NN-18NPK-R1
  • Perfil da Ventoinha Sem-LED
  • Tipo de Rolamento da Ventoinha Rolamento de Rifle
  • Velocidade da Ventoinha 650-1800 RPM ± 10%
  • Fluxo de Ar da Ventoinha 62 CFM ± 10%
  • Pressão de Ar da Ventoinha 2.5 mmH2O ± 10%
  • Ruído da Ventoinha 8 - 27 dBA
  • Dimensões (L x W x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1 polegada
  • Ventoinha MTTF 160,000 Horas
  • Voltagem da Ventoinha 12 VDC
  • Corrente da Ventoinha 0.15A
  • Corrente Segura Da Ventoinha 0.37A
  • Consumo da Ventoinha 1.8W
  • Conector de Energia da Ventoinha 4-Pinos (PWM)
  • Peso da Ventoinha 156g / 0.34 lbs
  • Garantia 2 anos
  • Cooler Type Case Fan
  • Série SickleFlow
  • Ventoinha - Iluminação LED Sem-LED
  • Tamanho da Ventoinha 120
