Notepal U150R image number 0
Notepal U150R image number 1
Notepal U150R image number 2
Notepal U150R image number 3
Notepal U150R image number 4
Notepal U150R image number 5
Notepal U150R image number 6
Notepal U150R
Notepal U150R
Notepal U150R
Notepal U150R
Notepal U150R
Notepal U150R
Notepal U150R
ULTRA FINO. ULTRAPODEROSO. QUALIDADE PREMIUM SEM BARULHO
Notepal U150R
Notepal U150R
Especificações
  • Modelo R9-U150R-16FK-R1
  • Cor Space Silver
  • Material Aluminum, Metalmesh, Plastic, Rubber
  • Dimensões (L x W x H) 335 x 265 x 50 mm / 13.2 x 10.4 x 2.0 inch
  • Dimensões da Ventoinha (L x W x H) 80 x 80 x 15 mm / 3.2 x 3.2 x 0.6 inch
  • Velocidade da Ventoinha 1600 RPM ± 200
  • Fluxo de Ar da Ventoinha 13.5 CFM
  • Pressão de Ar da Ventoinha 0.6 mmH2O
  • Ruído da Ventoinha 29 dBA (Max)
  • Energia USB 5V DC
  • USB Micro USB x 1
  • Corrente 0.16A
  • Consumo de Energia 0.9W
  • Compatibilidade Supports up to 15" laptops
  • Garantia 2 years
  • Cooler Type Notebook Cooler
  • Série Notepal
