MM712 Sakura Limited Edition image number 0
MM712 Sakura Limited Edition image number 1
MM712 Sakura Limited Edition image number 2
MM712 Sakura Limited Edition image number 3
MM712 Sakura Limited Edition image number 4
MM712 Sakura Limited Edition image number 5
MM712 Sakura Limited Edition image number 6
MM712 Sakura Limited Edition image number 7
MM712 Sakura Limited Edition image number 8
MM712 Sakura Limited Edition image number 9
MM712 Sakura Limited Edition image number 10
MM712 Sakura Limited Edition image number 11
Prestígio leve
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
Comprar agora
Especificações
  • Modelo MM-712-WWOH2
  • Tipo de Grip do Mouse Palm / Claw
  • Material do Mouse ABS Plastic / Rubber / PTFE
  • Cor do Mouse Sakura Edition
  • Cor do LED do Mouse 16.7 Million RGB
  • Sensor do Mouse PixArt Optical Sensor
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-19000
  • Velocidade de Rastreamento do Mouse 400 ips
  • Distância de Levantamento do Mouse < ~2mm / Adjustable
  • Mouse Polling Rate 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • Angle Snapping Yes
  • Aceleração do Mouse 50g
  • Mouse Lifespan (L/R switches) Optical Switches, 70 Million
  • Botões do Mouse 6
  • Conectividade Wired / 2.4GHz / Bluetooth 5.1
  • Bateria 500 mAh
  • Battery Life Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • Charging Support Wired charging
  • OS Compatível Windows 8+ / macOS / Andriod / iOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Cabo do Mouse Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Dimensão do Mouse 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inches (L x W x H)
  • Peso do Mouse < 58g / 0.13 lbs (w/o Dongle & Cable)
  • Garantia 2 years
  • Produto Mice
