MasterBox NR600 with ODD image number 0
MasterBox NR600 with ODD image number 1
MasterBox NR600 with ODD image number 2
MasterBox NR600 with ODD image number 3
MasterBox NR600 with ODD image number 4
MasterBox NR600 with ODD image number 5
MasterBox NR600 with ODD image number 6
MasterBox NR600 with ODD image number 7
MasterBox NR600 with ODD image number 8
MasterBox NR600 with ODD image number 9
MasterBox NR600 with ODD image number 10
MasterBox NR600 with ODD image number 11
Forma & função simplificados
Streamlined, By Definition
Simplicity in aesthetics rarely reflect complexity in design. Cooler Master’s signature Fine Mesh spans the entire front panel for open airflow, makes up the structure of the case, and adds rigidity to its overall construction. Meticulously engineered for unhindered airflow, the MasterBox NR600 applies bold performance to a pure-and-simple design.
Minimalistic Design
Minimalistic Design
The MasterBox NR600 is a pure and simple design that is focused on airflow performance. A single-layer, fine mesh makes up the entire front panel, achieving efficient airflow while also acting as a dust filter.
Seamless Tempered Glass
The tempered glass side panel sits completely flush against the chassis, mounted securely and discreetly by a system of tabs and thumbscrews.
Ample Storage Support
A total of 5 x 2.5" and 4 x 3.5" drives can be mounted using a tool-less system. Storage can be mounted on the PSU shroud, behind the motherboard tray, and in the HDD cage.
2.5"
3.5"
Headset Jack
Fan Support
Front: 140mm x2 / 120mm x3
Top: 140mm x2 / 120mm x2
Rear: 120mm x1
*non ODD version
Radiator Support
Front: 360/280/240/140/120mm
Top: 120/240mm
(35mm max motherboard component height)
Rear: 120mm
*non ODD version
Component Clearances
Especificações
  • Modelo MCB-NR600-KG5N-S00
  • Cores do Exterior Preto
  • Materiais - Corpo Steel, Plastic
  • Materiais - Painel Lateral Vidro temperado
  • Dimensões (L x W x H) 478 (L) x 209 (W) x 473 (H) mm
  • Suporte da Placa Mãe Mini-ITX, Micro-ATX, ATX
  • Slot de Expansão 7
  • 5.25" Baías de Drivers 1
  • 3.5" Baías de Drivers 4
  • 2.5" Baías de Drivers 5
  • Vent. Pre-Instaladas - Fronta 1x 120mm
  • Vent. Pre-Instaladas - Fundo 1x 120mm
  • Suporte de Ventoinha - Frontal 2x 120mm / 2x 140mm
  • Suporte de Ventoinha - Topo 2x 120mm / 2x 140mm
  • Suporte de Ventoinha - Fundo 1x 120mm
  • Suporte do Radiador - Frontal 120 / 140 / 240 / 280mm
  • Suporte do Radiador - Topo 120mm/240mm (com ODD removido) (35mm altura máxima do componente da placa-mãe)
  • Suporte do Radiador - Fundo 120mm
  • Espaço - CPU Cooler 166mm
  • Espaço - PSU 160mm
  • Espaço - GFX 410mm
  • Roteamento de Cabos - Atrás da bandeja da placa-mãe 20-28mm / 0.78-1.10"
  • Filtros de Pó Top, Bottom
  • Suporte de Fonte de Alimentação Bottom Mount, ATX
  • Tamanho Mid Tower
  • Series MasterBox Series
