MasterBox NR200P V2 Mini-ITX PC Case image number 0
MasterBox NR200P V2 Mini-ITX PC Case image number 1
MasterBox NR200P V2 Mini-ITX PC Case image number 2
MasterBox NR200P V2 Mini-ITX PC Case image number 3
MasterBox NR200P V2 Mini-ITX PC Case image number 4
MasterBox NR200P V2 Mini-ITX PC Case image number 5
MasterBox NR200P V2 Mini-ITX PC Case image number 6
MasterBox NR200P V2 Mini-ITX PC Case image number 7
MasterBox NR200P V2 Mini-ITX PC Case image number 8
MasterBox NR200P V2 Mini-ITX PC Case image number 9
MasterBox NR200P V2 Mini-ITX PC Case image number 10
MasterBox NR200P V2 Mini-ITX PC Case image number 11
MasterBox NR200P V2 Mini-ITX PC Case image number 12
MasterBox NR200P V2 Mini-ITX PC Case image number 13
MasterBox NR200P V2 Mini-ITX PC Case image number 14
MasterBox NR200P V2 Mini-ITX PC Case image number 15
MasterBox NR200P V2 Mini-ITX PC Case image number 16
MasterBox NR200P V2 Mini-ITX PC Case image number 17
MasterBox NR200P V2 Mini-ITX PC Case image number 18
MasterBox NR200P V2 Mini-ITX PC Case image number 19
MasterBox NR200P V2 Mini-ITX PC Case image number 20
MasterBox NR200P V2 Mini-ITX PC Case image number 21
MasterBox NR200P V2 Mini-ITX PC Case image number 22
MasterBox NR200P V2 Mini-ITX PC Case image number 23
MasterBox NR200P V2 Mini-ITX PC Case image number 24
MasterBox NR200P V2 Mini-ITX PC Case image number 25
Grandes possibilidades, tamanho pequeno
Compacto, mas poderoso
Mantenha a calma sob pressão
Desempenho de GPU otimizado
Ampla compatibilidade com GPU
Acesso fácil e sem ferramentas
Suporte a USB 3.2 Gen 2x2 Type C
Estilo NCORE renovado
Cor
Comprar agora
Sistema de Refrigeração
240-280MM
WATER COOLERS
18,25 L
DESIGN ULTRA ELEGANTE
Extra Cool
120MM
VENTOINHA INFERIOR
SUPORTE COMPLETO A GPU
Inclui opções de montagem vertical, um cabo riser PCIe 4.0 personalizado e um suporte para GPUs de até 356mm de comprimento e 160mm de altura.
Especificações
  • Número do modelo MasterBox NR200P V2: NR200PV2-KCNN-S00, MasterBox NR200P V2 White: NR200PV2-WCNN-S00
  • Cor externa Black, White / Grey
  • Materiais - Exterior SGCC Steel, Mesh, ABS Plastic
  • Materiais - Painel lateral esquerdo Tempered Glass x1, Steel x1
  • Dimensões (C x L x A) 372 x 185 x 292mm (incl. Protrusions), 360 x 185 x 274mm (excl. Protrusions)
  • Volume 18.25L
  • Suporte para placa-mãe Mini-ITX, Max. size: 170 x180mm
  • Slots de expansão 3
  • Baias de unidade de 5.25" 0
  • Baias de unidade de 3.5" 1 (Max. 2, remove bottom fan)
  • Baias para unidades de 2.5" / 3.5" (combo) 1
  • Baias para unidades de 2.5" 1 (Max. 2)
  • Painel de I/O - Portas USB 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen 2x2 Type C
  • Painel I/O - Entrada / Saída de áudio 1x 3.5mm Headset Jack (Audio+Mic)
  • Acessórios inclusos 1x PCIe 4.0 x16 riser cable, 1x GPU Holder
  • Ventoinhas pré-instaladas - Superior N/A
  • Ventoinhas pré-instaladas - Frontal N/A
  • Ventoinhas pré-instaladas - Traseira N/A
  • Ventoinhas pré-instaladas - Inferior 1x 120mm 650~1800rpm PWM SickleFlow
  • Suporte para ventoinhas - Superior 2x 120/140mm
  • Suporte para ventoinhas - Lateral N/A
  • Suporte para ventoinhas - Traseira N/A
  • Suporte para ventoinhas - Inferior 2x 120mm (1x max 15mm, w/o 3.5" HDD at the bottom)
  • Suporte para Radiador - Superior 120 / 140 / 240 / 280mm
  • Suporte para Radiador - Lateral N/A
  • Suporte para radiador - Traseiro N/A
  • Suporte para Radiador - Inferior N/A
  • Espaço máximo - Cooler de CPU 67mm
  • Espaço disponível - PSU 130mm
  • Espaço disponível - GPU Exceed front bracket: L: 357mm (incl. power connector) , H: 160mm (incl. power connector) , W: 73mm (triple slot); Not exceed front bracket: L: 334mm (incl. power connector) , H: 160mm (incl. power connector) , W: 80mm (triple slot)
  • Filtros de poeira Bottom, Left, Right, Top Panels
  • Suporte para fonte de alimentação SFX, SFX-L
  • Garantia 2 years
  • Série MasterBox Series
  • Tamanho Mini ITX
