ERGOSTAND IV image number 0
ERGOSTAND IV image number 1
ERGOSTAND IV
ERGOSTAND IV
SIMPLES AINDA PODEROSO
ERGOSTAND IV
ERGOSTAND IV
Ergostand IV
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
Ergostand IV
Ergostand IV
Ergonomic Design
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
Full Mesh Board
Led Strip & Additional USB Hub
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
Silent Cooling
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
Especificações
  • Modelo R9-NBS-E42K-GP
  • Cor Preto
  • Material Metal Mesh, Plastic, Rubber
  • Fitas LED Azul
  • Dimensões (L x W x H) 370 x 265 x 40 mm
  • Dimensões da Ventoinha (L x W x H) 140 x 140 x 15 mm / 5.5 x 5.5 x 0.6 polegada
  • Velocidade da Ventoinha 700–1400 RPM ± 150
  • Fluxo de Ar da Ventoinha 46.8 CFM ± 10%
  • Pressão de Ar da Ventoinha 1.24 mmH2O
  • Ruído da Ventoinha 29 dBA (Max)
  • Energia USB 5V DC
  • USB USB 2.0 x 4, Mini x 1, Micro x 1
  • Corrente de Consumo 0.20A
  • Consumo de Energia 1.0W
  • Compatibilidade Suporta laptops de até 17 "
  • Garantia 2 anos
  • Cooler Type Notebook Cooler
  • Série Ergostand
