Kapasitas kartu grafisOne graphics card per holder
PersyaratanRequires seven PCI case slots
Model Kabel RiserRiser Cable PCIe 3.0
DukunganPCI area of your Case
Berat Bersih0.230Kg
WarnaDark Metallic Grey
LegacyAccessories
CatatanThis product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
