MasterBox TD500 Mesh Mid Tower Case image number 0
MasterBox TD500 Mesh Mid Tower Case image number 1
MasterBox TD500 Mesh Mid Tower Case image number 2
MasterBox TD500 Mesh Mid Tower Case image number 3
MasterBox TD500 Mesh Mid Tower Case image number 4
MasterBox TD500 Mesh Mid Tower Case image number 5
MasterBox TD500 Mesh Mid Tower Case image number 6
MasterBox TD500 Mesh Mid Tower Case image number 7
MasterBox TD500 Mesh Mid Tower Case image number 8
MasterBox TD500 Mesh Mid Tower Case image number 9
MasterBox TD500 Mesh Mid Tower Case image number 10
MasterBox TD500 Mesh Mid Tower Case image number 11
MasterBox TD500 Mesh Mid Tower Case image number 12
MasterBox TD500 Mesh Mid Tower Case image number 13
MasterBox TD500 Mesh Mid Tower Case image number 14
MasterBox TD500 Mesh Mid Tower Case image number 15
MasterBox TD500 Mesh Mid Tower Case image number 16
MasterBox TD500 Mesh Mid Tower Case image number 17
MasterBox TD500 Mesh Mid Tower Case image number 18
MasterBox TD500 Mesh Mid Tower Case image number 19
MasterBox TD500 Mesh Mid Tower Case image number 20
MasterBox TD500 Mesh Mid Tower Case image number 21
Elegan Tanpa Ampun
Mesh Poligonal
Kaca Tempered Kristal
Tiga Kipas ARGB
Dukungan Radiator Ganda 360mm
Opsi Pendinginan Serbaguna
Ruang untuk Upgrade
Spesifikasi
  • Dukungan Radiator - Belakang 120mm
  • Dukungan Power Supply Bottom Mount
  • Filter Debu Top
  • Slot Drive 5,25" N/A
  • Material - Eksterior Mesh
  • Material - Panel Samping Kiri Tempered Glass
  • Material - Eksterior Steel
  • Kipas Terpasang - Atas N/A
  • Filter Debu Front
  • Garansi 2 years
  • Bay Drive 2.5" / 3.5" (Kombo) 2
  • Dukungan Radiator - Depan 360mm
  • Warna Black
  • Seri MasterBox Series
  • Ukuran Mid Tower
  • Warna White
  • Dukungan Radiator - Atas 360mm
  • Filter Debu Bottom
  • Dukungan Motherboard SSI CEB
  • Dukungan Power Supply ATX
  • Ruang - PSU 180mm/7.08"
  • Material - Eksterior Plastic
  • Dukungan Kipas - Belakang 1x 120mm
  • Dukungan Radiator - Depan 280mm
  • Dukungan Radiator - Depan 240mm
  • Dukungan Radiator - Atas 240mm
  • Dukungan Motherboard E-ATX*
  • Dukungan Kipas - Depan 2x 140mm
  • Slot Ekspansi 7
  • Dukungan Radiator - Depan 140mm
  • Dukungan Motherboard ATX
  • Dukungan Motherboard Micro ATX
  • Dukungan Radiator - Atas 120mm
  • Dukungan Radiator - Depan 120mm
  • Pengaturan Kabel 19mm/0.74"
  • Dukungan Kipas - Atas 2x 140mm
  • Dukungan Kipas - Depan 3x 120mm
  • Ruang Maksimum - Pendingin CPU 165mm/6.49"
  • Kipas Terpasang - Belakang N/A
  • Dukungan Kipas - Atas 3x 120mm
  • Dukungan Motherboard Mini ITX
  • Dukungan Radiator - Atas (44mm max motherboard component height)
  • Dukungan Motherboard (*up to 12” x 10.7” motherboards)
  • Ruang - PSU 295mm/11.61" (w/ HDD cage removed)
  • Volume 40.14L (excl. Protrusions)
  • Ruang - Kartu Grafis 410mm/16.1"
  • Kipas Terpasang - Depan 3x 120mm CF120 ARGB
  • Bay Drive 2.5" 4 (2+2 combo)
  • Panel I/O 2 x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB Hub, 1x ARGB 1-to-3 Splitter
  • Dimensi (P x L x T) 493 x 217 x 469mm (incl. Protrusions)
  • Dimensi (P x L x T) 429.5 x 205x 447mm (excl. Protrusions)
  • Nomor Model MCB-D500D-KGNN-S01 (Mesh w/ Hub)
  • Nomor Model MCB-D500D-KGNN-S00 (Mesh w/o controller)
  • Nomor Model MCB-D500D-WGNN-S01 (Mesh White w/ Hub)
  • Nomor Model MCB-D500D-WGNN-S00 (Mesh White w/o controller)
Unduhan
  • Lembar Produk MasterBox TD500 Mesh (upgrade CF120 setelah pembaruan 2022) Download
  • Lembar Produk MasterBox TD500 Mesh White (upgrade CF120 setelah upgrade 2022) Download
  • MasterBox TD500 Mesh White - Lembar Produk (Kontroler ARGB SN sebelum pembaruan 2022) Download
  • MasterBox TD500 Mesh White - Lembar Produk (ARGB PWM Hub SN setelah pembaruan 2022) Download
  • MasterBox TD500 Mesh - Lembar Produk (SN Kontroler ARGB sebelum pembaruan 2022) Download
  • MasterBox TD500 Mesh - Lembar Produk (Hub ARGB PWM SN setelah pembaruan 2022) Download
  • MasterBox TD500 Mesh - Manual Download
  • Kontroler ARGB Kecil - Lembar Produk Download
  • ARGB PWM HUB - Lembar produk Download
