MasterBox TD500 ARGB Mid Tower Case image number 0
MasterBox TD500 ARGB Mid Tower Case image number 1
MasterBox TD500 ARGB Mid Tower Case image number 2
MasterBox TD500 ARGB Mid Tower Case image number 3
MasterBox TD500 ARGB Mid Tower Case image number 4
MasterBox TD500 ARGB Mid Tower Case image number 5
MasterBox TD500 ARGB Mid Tower Case image number 6
MasterBox TD500 ARGB Mid Tower Case image number 7
MasterBox TD500 ARGB Mid Tower Case image number 8
MasterBox TD500 ARGB Mid Tower Case image number 9
MasterBox TD500 ARGB Mid Tower Case image number 10
MasterBox TD500 ARGB Mid Tower Case image number 11
Tunjukkan Gaya Anda
Casing ATX MasterBox TD500 ARGB menghadirkan pencahayaan PC dari perspektif yang benar-benar baru.
Spesifikasi
  • Dukungan Radiator - Belakang 120mm
  • Filter Debu Top
  • Dukungan Catu Daya Bottom Mount
  • Bay Drive 5.25" N/A
  • Garansi 2 years
  • Bay Drive 2.5" / 3.5" (Kombo) 2
  • Filter Debu Front
  • Warna Black
  • Seri MasterBox Series
  • Ukuran Mid Tower
  • Dukungan Radiator - Depan 360mm
  • Material - Eksterior Steel
  • Material - Eksterior Plastic
  • Filter Debu Bottom
  • Dukungan Radiator - Atas 360mm
  • Dukungan Catu Daya ATX
  • Kipas Terpasang - Belakang 1x 120mm (Black)
  • Ruang - PSU 180mm/7.08"
  • Dukungan Kipas - Belakang 1x 120mm
  • Dukungan Radiator - Depan 280mm
  • Dukungan Radiator - Depan 240mm
  • Dukungan Radiator - Atas 240mm
  • Dukungan Motherboard E-ATX*
  • Bahan - Panel Samping Kiri Acrylic
  • Dukungan Kipas - Depan 2x 140mm
  • Slot Ekspansi 7
  • Dukungan Radiator - Depan 140mm
  • Dukungan Motherboard ATX
  • Dukungan Motherboard Micro ATX
  • Dukungan Radiator - Atas 120mm
  • Dukungan Radiator - Depan 120mm
  • Pengaturan Kabel 19mm/0.74"
  • Dukungan Kipas - Atas 2x 140mm
  • Dukungan Kipas - Depan 3x 120mm
  • Ruang Maksimum - Pendingin CPU 165mm/6.49"
  • Dukungan Kipas - Atas 3x 120mm
  • Dukungan Motherboard Mini ITX
  • Dukungan Radiator - Atas (44mm max motherboard component height)
  • Dukungan Motherboard (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Ruang - GPU 410mm/16.1"
  • Kipas Terpasang - Depan 3x 120mm CF120 ARGB
  • Bay Drive 2.5" 4 (2+2 combo)
  • Panel I/O 2x USB 3.2 Gen 1 (USB 3.0), 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB Hub
  • Dimensi (P x L x T) 493 x 217 x 469mm (incl. Protrusions)
  • Dimensi (P x L x T) 429.5 x 205 x 447mm (excl. Protrusions)
  • Nomor Model MCB-D500D-KANN-S01
Unduhan
  • MasterBox TD500 ARGB - Lembar Produk (upgrade CF120 setelah upgrade 2022) Download
  • MasterBox TD500 ARGB - Lembar Produk (SN Pengontrol ARGB sebelum pembaruan 2022) Download
  • MasterBox TD500 ARGB - Lembar Produk (Hub PWM ARGB, SN setelah pembaruan 2022) Download
  • MasterBox TD500 ARGB - Panduan Download
  • Kontroler ARGB Kecil - Lembar Produk Download
  • ARGB PWM HUB - Lembar Produk Download
