MasterBox MB400L Steel image number 0
MasterBox MB400L Steel image number 1
MasterBox MB400L Steel image number 2
MasterBox MB400L Steel image number 3
MasterBox MB400L Steel image number 4
MasterBox MB400L Steel image number 5
MasterBox MB400L Steel image number 6
MasterBox MB400L Steel image number 7
MasterBox MB400L Steel image number 8
MasterBox MB400L Steel image number 9
Desain yang cerdas
Setiap elemen MasterBox MB400L diciptakan dari palet yang elegan. Dengan hasil akhir brushed, corak warna yang halus, dan Cooler Master yang minimalis...
Spesifikasi
  • Bahan Steel
  • Dukungan Radiator - Belakang 120mm
  • Filter Debu Top
  • Dukungan Power Supply Bottom Mount
  • Ruang - PSU 140mm (HDD cage in backmost position)
  • Garansi 2 years
  • Kipas Terpasang - Atas N/A
  • Filter Debu Front
  • Bay Drive 3.5" 2
  • Bahan Plastic
  • Warna Black
  • Seri MasterBox Series
  • Ukuran Mini Tower
  • Slot Drive 5,25" 1
  • Bay Drive 2.5" 2
  • Filter Debu Bottom
  • Kipas Terpasang - Belakang 1x 120mm (Black)
  • Dukungan Power Supply ATX
  • Dukungan Kipas - Belakang 1x 120mm
  • Dukungan Radiator - Depan 240mm
  • Dukungan Kipas - Depan 2x 140mm
  • Dukungan Radiator - Depan 140mm
  • Dukungan Motherboard Micro ATX
  • Dukungan Radiator - Atas 120mm
  • Dukungan Radiator - Depan 120mm
  • Bahan Mesh
  • Pengaturan Kabel 18-22mm
  • Ruang - PSU 325mm (w/o front radiator & HDD cage)
  • Dukungan Kipas - Atas 1x 140mm
  • Dukungan Kipas - Depan 2x 120mm
  • Slot Ekspansi 4
  • Dukungan Motherboard Mini ITX
  • Dukungan Kipas - Atas 1x 120mm
  • Dukungan Radiator - Depan 280mm (remove & reinstall ODD bracket to mount 280mm radiator)
  • Ruang Maksimum - Pendingin CPU Steel: 167mm
  • Kipas Terpasang - Depan N/A
  • Dukungan Kipas - Depan Mount behind the front plate
  • Berat 5.47kg
  • Panel I/O 1x 3.5mm Headset Jack (Audio+Mic)
  • Ruang - Kartu Grafis 344mm
  • Panel I/O 2x USB 3.2 Gen 1 (USB 3.0)
  • Dimensi (P x L x T) 411 x 210 x 410mm (Steel Incl. Protrusions)
  • Dimensi (P x L x T) 396 x 210 x 400mm (Excl. Protrusions)
  • Nomor Model MCB-B400L-KN5N-S00
Unduhan
