Kantor Pusat Sedunia
398, Xinhu 1st Rd, Distrik Neihu, Kota Taipei, 114, Taiwan
Minimalist Design, Maximalist Thermal Power
• Superconductive Composite Heat Pipes
• Ultra-Performance Mobius 120U Fans
• Integrated Metal Top Cover
• Quick Fan Installation System
• Extreme Performance
• Multiple Color Options
The Hyper 612 APEX PRO is a high-performance single-tower cooler featuring superconductive composite heat pipes and ultra-fast 2700 RPM Mobius 120U fans. Designed for creators and aesthetic builders, its offset heatsink ensures 100% RAM visibility, while the integrated metal top cover provides a professional finish. It delivers elite cooling through efficiency and effortless installation.
Features in-house designed superconductive composite heat pipes that enhance thermal transfer efficiency, delivering a significant temperature drop compared to standard designs.
Equipped with high-speed 2700 RPM Mobius 120U fans, providing the high static pressure and airflow required for intensive rendering and data processing.
A premium integrated metal top cover offers a clean, professional minimalist aesthetic that complements high-end workstation and studio builds.
Designed for maximum efficiency, the intuitive mounting system allows for a fast and effortless installation process, reducing assembly time for DIY enthusiasts and professionals alike.
With our unique offset heatsink design, you can easily build with lots of room for memory and GPU.
Hyper 612 APEX PRO is available in black, white, and a silver edition specially designed for silver chassis, offering versatile color options for a more unified system appearance.
