Elite 500 image number 0
Elite 500 image number 1
Elite 500 image number 2
Elite 500 image number 3
Elite 500 image number 4
Elite 500 image number 5
Elite 500 image number 6
Elite 500 image number 7
Elite 500 image number 8
Elite 500 image number 9
Elite 500 image number 10
Elite 500 image number 11
Elite 500 image number 12
Elite 500 image number 13
Elite 500 image number 14
Elite 500 image number 15
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
Elite 500
WITH/WITHOUT ODD SUPPORT
Elite 500
Elite 500 adalah solusi penting untuk pendinginan yang optimal. Ventilasi besar di panel depan memungkinkan udara segar masuk ke sistem
Beli Sekarang
Spesifikasi
  • Dust Filters Top
  • Kensington Lock N/A
  • Dust Filters Front
  • Color(s) Black
  • Size Mid Tower
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Series Elite Series
  • Motherboard Support ATX
  • Expansion Slots 7
  • Fan Support - Top 2x 140mm
  • Cable Routing 18.5mm
  • Volume 37.29L (E500-KGNN-S00, E500-KNNN-S00) (exlc. Protrusions), 42.40L (E500-KG5N-S00, E500-KN5N-S00) (exlc. Protrusions)
  • Fan Support - Top 2x 120mm
  • I/O Panel 2x USB 3.2 Gen 1 Type-A
  • Radiator Support - Front 360mm (Remove ODD) (E500-KG5N-S00, E500-KN5N-S00)
  • Radiator Support - Top 120 / 240mm (32mm max motherboard component height)
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - PSU 160mm (E500-KGNN-S00, E500-KNNN-S00), 180mm (E500-KG5N-S00, E500-KN5N-S00)
  • Clearance - CPU Cooler TG: 161mm, Steel: 163mm
  • Fan Support - Front 2x 140mm, 3x 120mm (E500-KGNN-S00, E500-KNNN-S00), 2x 120mm (E500-KGNN-S00, E500-KNNN-S00), 3x 120mm (remove ODD bracket) (E500-KGNN-S00, E500-KNNN-S00)
  • 5.25" Drive Bays 0 (E500-KGNN-S00, E500-KNNN-S00), 1 (E500-KG5N-S00, E500-KN5N-S00)
  • 2.5" Drive Bays 3 (E500-KGNN-S00, E500-KNNN-S00), 5 (E500-KG5N-S00, E500-KN5N-S00)
  • Materials Steel, Plastic, Tempered Glass
  • Clearance - GFX 350mm (w/o front fans & radiator) (E500-KGNN-S00, E500-KNNN-S00), 400mm (w/o front fans & radiator) (E500-KG5N-S00, E500-KN5N-S00)
  • Dimensions (L x W x H) 409 x 204 x 455mm (incl. Protrusions), 402 x 204 x 455mm (excl. Protrusions), 464 x 204 x 455mm (incl Protrusions, ODD), 457 x 204 x 455mm (excl. Protrusions, ODD)
  • Model Number E500-KGNN-S00 (TG), E500-KNNN-S00 (Steel), E500-KG5N-S00 (TG, ODD), E500-KN5N-S00 (Steel, ODD)
