CMP 320 image number 0
CMP 320 image number 1
CMP 320 image number 2
CMP 320 image number 3
CMP 320 image number 4
CMP 320 image number 5
CMP 320 image number 6
CMP 320 image number 7
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
CMP 320
Ample Airflow, ARGB Brilliance
CMP 320
CMP 320 memberikan tampilan estetika yang premium, thermal yang optimal, performa yang hebat: semua itu hanya memakan sedikit ruang di ruang gaming Anda.
Beli Sekarang
Spesifikasi
  • Model Number CP320-KGNN-S00
  • Exterior Color Black
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 445.5 x 204 x 425mm (Incl. Protrusions), 431.8 x 204 x 410mm (Excl. Protrusions)
  • Volume 38.52L (Excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 2
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 2.0
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • ARGB Controller ARGB Fans Hub
  • Pre-installed Fans - Front 2x CF120 ARGB
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Front 2x120mm / 3x120mm (*Installed inside the case only)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280mm (*Recommend AIO tubes face rear to avoid interference)
  • Clearance - CPU Cooler 163.5mm
  • Clearance - PSU 160mm
  • Clearance - GFX 365mm (without front fans & radiator)
  • Cable Routing 16.5mm
  • Dust Filters Top, Bottom
  • Size Mini Tower
  • Series CMP Series
  • CMP 320 Product Sheet (CF120 ARGB+Hub) SN after CP320KGNNS001224700001 Download
  • CMP 320 Product Sheet (CF120P ARGB+CF120S ARGB) Download
  • CMP 320 Manual (CF120 ARGB+ Hub SN after CP320KGNNS001224700001) Download
