Kantor Pusat Sedunia
398, Xinhu 1st Rd, Distrik Neihu, Kota Taipei, 114, Taiwan
Quiet Colorful Cooling
Cooler Master’s CF120 ARGB is the most well rounded fan solution for your case and chassis.
The frame is constructed with reinforced PBT for stability, with air balance fan blades for high airflow and cooling performance
The flexible mounting system is anti-resonance for noise minimization
Vibrant ARGB lighting to add the touch of color to your build, Compatible with major Motherboards.
