Wired RGB Controller C10L image number 0
Wired RGB Controller C10L image number 1
Wired RGB Controller C10L image number 2
Wired RGB Controller C10L image number 3
Wired RGB Controller C10L image number 4
Wired RGB Controller C10L image number 5
Wired RGB Controller C10L image number 6
RGB IN THE PALM OF YOUR HAND
Specificaties
  • Material Plastic
  • Output Channel Voltage 12V
  • Material PCB
  • Connector 4-Pin
  • Included Accessories Extension Cable x 1
  • Cooler Type RGB Accessories
  • Rated Current 2A
  • Dimensions (L x W x H) 45 x 16 x 8mm
  • Series RGB Accessories
  • EAN code 4719512064757
  • UPC code 884102037429
  • Product Number RE-C10L-RGB-R1
