Maak ervan wat je wilt!
Vertical Graphics Card Holder Kit
Verticale grafische kaarthouder-kit
Specificaties
Capaciteit grafische kaartOne graphics card per holder
VereisteRequires seven PCI case slots
Riser-kabelmodelRiser Cable PCIe 3.0
OndersteuningPCI area of your Case
Nettogewicht0.230Kg
Kleur(en)Dark Metallic Grey
LegacyAccessories
OpmerkingThis product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
