Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 0
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 1
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 2
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 3
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 4
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 5
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 6
Make Of It What You Will
The Cooler Master Universal Vertical Graphics Card Holder Kit V2 has been upgraded to include a PCIe 4.0 riser cable
Specificaties
  • Model Number MCA-U000R-KFVK02
  • Color(s) Black / Purple
  • Dimensions (L x W x H) GFX Holder Kit: 184 x 142 x 121mm (closed), GFX Holder Kit: 239 x 142 x 121mm (fully open), Riser Cable: 165mm (6.19in)
  • Supported Graphics Cards Any length, up to 2.5 slots wide
  • Riser Cable Model Riser Cable PCIe 4.0 x16
  • Compatibility PCIe 4.0 and older
  • CE Certifications Number BKC210933AC
  • PCB / Wire UL Numbers E189572 / E252840
  • Electronic Component Materials PCBA, Tinned Copper Wire 30 AWG
  • Insulation Materials PE, TPE
  • Other Materials ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Rated Working Voltage and Current DC 12V / 5A
  • Operating Temperature -20° to +100° Celsius
  • Required PCI slots 7 PCI slots are required for mounting
  • Weight 0.43 kg
  • Warranty 1 year
  • Series Others
