THRONE X image number 0
THRONE X image number 1
THRONE X image number 2
THRONE X image number 3
THRONE X image number 4
THRONE X
THRONE X
THRONE X
THRONE X
THRONE X
THRONE X
Metronome
The Throne X, a multi-purpose immersive stool designed for musicians, provides a tactile experience that enables one to physically feel the tempo. Moreover, being the industry’s first musician stool to actively provide vibrations even without input, the Throne X can serve as a metronome for musicians to improve their skills, both during practice and performance.
Metronome
Metronome
Immersive performance
Multi-use
The multi-mode functionality provides unique settings for several use cases. In audio mode, the stool vibrates based on musical input or the rhythm of your bandmates. In metronome mode, the stool helps you keep the beat. In real-time mode, the stool vibrates to the rhythm of your performance.
User-friendly
Perfect companion to artists on-the-go
A foldable stand and a backpack for storing the stool makes travel easier for touring musicians.
Long-lasting comfort
Convenient, Lag-Free Controller
A built-in wired controller allows you to easily change mode, adjust speed and tempo, and modify vibration intensity.
Seamlessly Integrate with PA Systems
With easy PA integration, you can easily synchronize with other performers and create a more immersive stage experience.
Solid Construction
Solid Construction
A well-structured frame and support delivers high durability and withstands prolonged hours of vibrations.
EXTENSIVE COMPATABILITY
The Throne X includes inputs for 3.5mm aux, 6.3mm aux, 6.3mm dynamic microphone, and 3.5mm headphones.
TWO-STAGE HEIGHT ADJUSTABLE
The standard fixed stand offers advanced comfort and options for different heights to meet your needs.
SELF-CENTERING
Designed with self-aligning torque, the seat always returns to center position after musician stands up even if the seat has been turned during use.
Specificaties
  • Product Number IXC-TX1-***
  • Chair Dimensions (L x W x H) 20.7" x 20.7" x 22.28"~26.77" / 52.6 x 52.6 x 56.6~68 cm
  • Chair Weight 34.8 lbs, 15.8 kg
  • Backpack Dimensions (W x D x H) 19.6" x 11.8" x 23.6" ~ 50cm x 30cm x 60cm
  • Color Choice Cloud Gray
  • Chair Material High density molded memory foam upholstered in breathable fabric
  • Safety Load 300 lbs. (136 kg) human body bearing
  • Main Body Aluminum and wood frame
  • Gas Lift Height Adjustment 90 mm, class 4 grade
  • Column Height Adjustment 32 mm
  • Frequency Range 20 Hz ~ 200 Hz
  • Battery Module Rechargeable lithium-ion battery pack (8-cell), 14.8V 6400mAh, core cells of LG, Provides approximately 10 hours of continuous music play and 6 hours of continuous use of intense bass effects
  • Charging Time About 5 hours
