Silencio S400 White Mini Tower PC Case image number 0
Silencio S400 White Mini Tower PC Case image number 1
Silencio S400 White Mini Tower PC Case image number 2
Silencio S400 White Mini Tower PC Case image number 3
Silencio S400 White Mini Tower PC Case image number 4
Silencio S400 White Mini Tower PC Case image number 5
Silencio S400 White Mini Tower PC Case image number 6
Silencio S400 White Mini Tower PC Case image number 7
Silencio S400 White Mini Tower PC Case image number 8
Silence Has a Sequel
The Silencio S400 is now available in white to match the clean, pristine aesthetics of modern gaming décor.
Silencio Design
Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
Silencio Technology
Silencio Technology
Behind the outer panels are pieces of meticulously placed sound dampening material. The development of the Silencio was driven by Sorama’s Cam64—this allowed for the entire sound spectrum to be visually analyzed by source, resonance pattern, and frequency.
With the identification of peaks within certain frequency ranges, fine-tuning the Silencio for the dispersion of resonance was made possible, reducing the prominence of noise generated by system components. Every detail in design optimized the Silencio for thermal efficiency and silence, from the type of material used to its placement.
Sound Dampening Material
Seamless Tempered Glass or Sound-dampened Steel
Available with seamless tempered glass or a sounddampened steel side panel, systems can be built for show or for stealth with the Silencio.
Top Panel Options
Reversible Steel Door & ODD Support
(re)movable Drive Cage
Motherboard Support
Motherboard Support
Mini-itx, Micro-atx
Cooling Support
Cooling Support
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2* Fans
120 / 240mm* Radiator
*remove ODD cage
Front:
120 / 140mm x 2 Fans
120 / 140 / 240 / 280mm* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
Storage Support
5.25inch ODD x 1
3.5inch HDD x 4
2.5inch SSD x 4
Specificaties
  • Modelnummer Steel: MCS-S400-WN5N-SJP, TG: MCS-S400-WG5N-SJP
  • Buitenkleur Black
  • Materialen - Behuizing Steel, Plastic, Sound Absorbing Material
  • Materialen – linkerzijpaneel Sound-Dampened Steel (MCS-S400-WN5N-SJP), Tempered Glass (MCS-S400-WG5N-SJP)
  • Afmetingen (L x B x H) 418 x 210 x 408mm (incl. Protrusions), 403.5 x 210 x 400mm (excl. Protrusions)
  • Volume 33.9L (excl. Protrusions)
  • Ondersteuning voor moederborden Mini-ITX, Micro-ATX
  • Uitbreidingssleuven 4
  • 5,25"-schijfbays 1
  • 3,5"-schijfbays 4
  • 2,5"-drivebays 4
  • I/O-paneel – USB-poorten 1x USB 3.0, 1x USB 3.1 Type C
  • I/O-paneel – Audio in / uit 1x 3.5mm Headset Jack (Audio+Mic)
  • I/O-paneel - SD-kaartlezer Supports SD & MMC Cards
  • Vooraf geïnstalleerde ventilatoren – voorkant 1x CF120 non-Led (White)
  • Vooraf geïnstalleerde ventilatoren – Achter 1x CF120 non-Led (White)
  • Ventilatorondersteuning - Voorzijde 2x 120/140mm
  • Ventilatorondersteuning – Boven 1x 120mm, 1x 140mm / 2x 120mm, 2x 140mm (remove ODD cage)
  • Ventilatorondersteuning – Achter 1x 120mm
  • Radiatorondersteuning – Voorzijde 120 / 140 / 240 / 280mm (remove & reinstall ODD bracket to mount 280mm radiator, may interfere with HDD mounted below ODD bracket)
  • Radiatorondersteuning – Boven 120mm, 240mm* (*240mm requires removal of ODD cage)
  • Radiatorondersteuning – Achter 120mm
  • Vrije ruimte - CPU-koeler Steel: 167mm, TG: 166mm
  • Ruimte – Voeding 325mm (w/o front radiator & drive cage), 140mm (HDD cage in backmost position)
  • Ruimte - Grafische kaart 319mm
  • Kabelgeleiding 20mm
  • Stoffilters Front, Top, Bottom
  • Voedingsondersteuning Bottom Mount, ATX PS2
  • Maat Mini Tower
  • Serie Silencio Series
