Riser Cable PCIe 4.0 x16 - 200mm image number 0
Riser Cable PCIe 4.0 x16 - 200mm image number 1
Riser Cable PCIe 4.0 x16 - 200mm image number 2
Riser Cable PCIe 4.0 x16 - 200mm image number 3
Riser Cable PCIe 4.0 x16 - 200mm image number 4
Riser Cable PCIe 4.0 x16 - 200mm image number 5
Flex your Graphics Muscle
The Cooler Master Riser Cable PCIe 4.0 x16 - 200mm is designed for greater data transmission efficiency, maximum flexibility and durability.
Specificaties
  • Model Number Black/Purple: MCA-U000C-KPCI40-200, White/Gray/Black: MCA-U000C-WPCI40-200
  • Units per package 1 piece per package
  • Color(s) Black / Purple, White / Gray / Black
  • Compatibility PCIe 4.0 and older
  • Certifications BKC210933AC
  • Component Materials Black/Purple: PCBA, tinned copper wire 30 AWG, White/Gray/Black: PCBA, Silver Plated Copper Wire 30 AWG
  • Insulation Materials PE, TPE
  • Connectors PCI-E x16 Male to PCI x16 90° Female
  • Cable Length 200mm
  • Contact Current Rating 1.1A per contact pin
  • Max Voltage Rating 30V
  • Working Voltage / Current DC 12V / 5A
  • PCB / Wire UL Numbers E189572 / E252840
  • Operating Temperature -20° to +100° Celsius
  • Weight 112 g
  • Warranty 1 year
  • Series Others
