RGB LED Controller image number 0
RGB LED Controller image number 1
RGB LED Controller image number 2
RGB LED Controller
RGB LED Controller
RGB LED Controller
Cool with Your Color
RGB LED Controller
RGB LED Controller
Specificaties
  • RGB LED Controller - Dimensions 90 x 53 x 14 mm / 3.54 x 2.08 x 0.55 inch
  • Material Plastic
  • Control Method Cooler Master Software
  • Input Connector SATA Power
  • Output Channel Voltage 12V
  • Output Channels 4
  • Lighting Mode Static
  • Included Accessories 450 mm Extension Cable x 4
  • Interface USB connectors (9 Pin)
  • Included Accessories 600 mm Extension Cable x 1
  • Lighting Mode Breathing
  • Output Channels Port 1, 2 for Frequency Control
  • Material PCB
  • Lighting Mode Color Cycle
  • Lighting Mode Stars
  • Warranty 5 years
  • Lighting Mode Customize
  • Lighting Mode Multilayer
  • Cooler Type RGB Accessories
  • Lighting Mode Turn LED Off
  • Lighting Mode Mirage (Frequency Control)
  • Weight 122g
  • Series RGB Accessories
  • Product Number MFY-RCSN-NNUDK-R1
