MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 0
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 1
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 2
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 3
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 4
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 5
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 6
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 7
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 8
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 9
80 PLUS Bronze-gecertificeerde voeding
• 80 PLUS Bronze
• DC-DC-schakelingontwerp
• Kwaliteitscondensatoren
• Duurzaam LDB-lager
• Laag stroomverbruik in stand-by
• Gevlochten kabels
Specificaties
  • Ingangsfrequentie 50-60Hz
  • Bedrijfstemperatuur 0-40°C
  • Bedrijfsspanning 100-240Vac
  • ErP 2013 Lot 6 Yes
  • MB 20+4-pins connectoren 1
  • FDD-kabel met 4-pins connectoren 1
  • Power Good-signaal 100 - 500 ms
  • Ventilatorgrootte 120mm
  • Lagertype ventilator LDB
  • Categorie 500 to 750W
  • CPU 12V 4+4-pins connectoren 1
  • Modulair Non Modular
  • ATX-versie ATX 12V V2.31
  • 80 Plus-efficiëntie Bronze
  • Efficiëntie 85% @ Typical Load
  • SATA-connectoren 8
  • PCI-e 6+2-pins connectoren 750W / 850W: x4 = 2x (600+120mm)​ 1000W: x3 = 3x (600mm)
  • Perifere 4-pins connectoren 4
  • Ingangsspanning 100-240Vac
  • Serie MWE Bronze Series
  • Beveiligingen OVP
  • Beveiligingen OPP
  • Afmetingen (L x B x H) 140 x 150 x 86 mm
  • Beveiligingen SCP
  • Beveiligingen UVP
  • Model MPX-6501-ACAAB
  • Beveiligingen OTP
  • Hold-uptijd 16ms at 80% Load
  • Beveiligingen OCP
  • Productnaam MWE Bronze 650
  • Ingangsstroom 750W / 850W: 10 – 6 A​ | 1000W: 15 – 8 A
  • Regelgeving CCC
  • Regelgeving CE
  • Regelgeving TUV-RH
  • Regelgeving RCM
  • Regelgeving EAC
  • Regelgeving cTUVus
  • Regelgeving FCC
  • Regelgeving BSMI
  • Regelgeving KC
