MM712 Sakura Limited Edition image number 0
MM712 Sakura Limited Edition image number 1
MM712 Sakura Limited Edition image number 2
MM712 Sakura Limited Edition image number 3
MM712 Sakura Limited Edition image number 4
MM712 Sakura Limited Edition image number 5
MM712 Sakura Limited Edition image number 6
MM712 Sakura Limited Edition image number 7
MM712 Sakura Limited Edition image number 8
MM712 Sakura Limited Edition image number 9
MM712 Sakura Limited Edition image number 10
MM712 Sakura Limited Edition image number 11
Lightweight Prestige
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
Nu kopen
Specificaties
  • Product Number MM-712-WWOH2
  • Mouse Grip Type Palm / Claw
  • Mouse Material ABS Plastic / Rubber / PTFE
  • Mouse Color Sakura Edition
  • Mouse LED Color 16.7 Million RGB
  • Mouse Sensor PixArt Optical Sensor
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-19000
  • Mouse Tracking Speed 400 ips
  • Mouse Lift Off Distance < ~2mm / Adjustable
  • Mouse Polling Rate 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • Angle Snapping Yes
  • Mouse acceleration 50g
  • Mouse Lifespan (L/R switches) Optical Switches, 70 Million
  • Mouse Buttons 6
  • Connectivity Wired / 2.4GHz / Bluetooth 5.1
  • Battery 500 mAh
  • Battery Life Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • Charging Support Wired charging
  • Compatible OS Windows 8+ / macOS / Andriod / iOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mouse Cable Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Mouse Dimensions 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inches (L x W x H)
  • Mouse Weight < 58g / 0.13 lbs (w/o Dongle & Cable)
  • Product Mice
