MasterLiquid ML120L V2 RGB image number 0
MasterLiquid ML120L V2 RGB image number 1
MasterLiquid ML120L V2 RGB image number 2
MasterLiquid ML120L V2 RGB image number 3
MasterLiquid ML120L V2 RGB image number 4
MasterLiquid ML120L V2 RGB image number 5
CoolerMaster MasterLiquid ML120L RGB V2 is a refreshed design from the popular MasterLiquid Lite Series that elevates the exterior design elements...
Specificaties
  • Product Number MLW-D12M-A18PC-R2
  • Exterior Color Black
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 socket
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 157 x 119.6 x 27.2 mm / 6.2 x 4.7 x 1.1 inch
  • Pump Dimensions 79.9 x 76 x 47 mm / 3.1 x 3 x 1.9 inch
  • Pump MTTF 70,000 Hours
  • Pump Noise Level < 10 dBA (Max)
  • Pump Connector 3-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 2.36 W
  • Fan Quantity 240: 2 PCS | 360: 3PCS
  • Fan LED RGB
  • Fan Speed 650-1800 RPM ± 5% (Max)
  • Fan Airflow 62 CFM (Max)
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.5 mmH₂O (Max)
  • Fan Life Expectancy 160,000 Hours
  • Fan Rated Current 0.15A
  • TDP 180 W
  • RAM Clearance N/A
  • Note Compatible with AMD AM5 although the older boxes may not stress it.
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
  • Radiator Size 120
