MasterLiquid Lite 240 image number 0
MasterLiquid Lite 240 image number 1
MasterLiquid Lite 240 image number 2
MasterLiquid Lite 240 image number 3
MasterLiquid Lite 240 image number 4
Stilte. Prestaties. All-in-One.
MasterLiquid Lite 240 is een Cooler Master origineel ontwerp en een aantrekkelijke instap in vloeistofkoeling.
Specificaties
  • Radiatormateriaal Aluminum
  • Nominale spanning pomp 12 VDC
  • MTTF pomp 70,000 Hours
  • Pompaansluiting 3-Pin
  • Type koeler Liquid Cooler
  • Garantie 2 years
  • Voedingsconnector ventilator 4-Pin (PWM)
  • CPU-socket LGA2066
  • CPU-socket LGA2011-v3
  • MTTF-ventilator 160,000 Hours
  • Radiatorgrootte 240
  • Afmetingen pomp 80.3 x 76 x 42.2 mm / 3.2 x 3.0 x 1.7 inch
  • Geluidsniveau pomp < 15 dBA
  • Radiatorafmetingen 277 x 119.6 x 27 mm / 10.9 x 4.71 x 1.1 inch
  • Ventilatorsnelheid 650-2000 RPM (PWM) ± 10%
  • CPU-socket LGA1700
  • CPU-socket LGA1200
  • CPU-socket LGA1156
  • CPU-socket LGA1155
  • CPU-socket LGA1151
  • CPU-socket LGA1150
  • Serie MasterLiquid Lite
  • Afmetingen (L x B x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1.0 inch
  • CPU-socket AM5
  • CPU-socket AM4
  • CPU-socket AM3+
  • CPU-socket AM3
  • CPU-socket AM2+
  • CPU-socket AM2
  • CPU-socket FM2+
  • CPU-socket FM2
  • CPU-socket FM1
  • Luchtdruk van de ventilator 2.34 mmH2O ± 10%
  • Opmerking For LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
  • Luchtstroom van ventilator 66.7 CFM ± 10%
  • Productnummer MLW-D24M-A20PW-R1
