MasterLiquid 360 ION White Edition image number 0
MasterLiquid 360 ION White Edition image number 1
EXPERIENCE COOLING IN HIGH DEFINITION
Gen X dual chamber design
2.1-inch LCD screen
Mobius 120P ARGB fans
ARGB Halo lighting
Highly customizable and compatible
Signature halo pump design
MLY-D36M-A24PZ-RW
Experience Cooling in High Definition
Cooler Master's latest flagship performance cooler, the MasterLiquid 360 Ion, is our first liquid cooler to feature an LCD display. The MasterLiquid 360 Ion gives you total display customization with top-tier cooling specs.
Gen X Dual Chamber Design
Our signature dual chamber pump has been refined for enhanced cooling synergy. Our impeller uses a single-piece design with improved structural strength and stability. The graphite ceramic shaft is highly sturdy and temperature resistant.
2.1-inch LCD Screen
2.1-inch LCD Screen
The Ion's pump features a 2.1-inch LCD screen, fully customizable with our MasterCtrl software. Meanwhile, Our ARGB halo lighting has been designed with the Cooler Master's signature aesthetic in mind.
DISCOVER MASTERCTRL
Highly Customizable and Compatible
Built-in features such as controllable ARGB lighting and automatic PWM adjustment are compatible with all major motherboards and allow for in-depth customization.
IN-HOUSE DESIGNED RADIATOR
Pre-installed with three Mobius 120P ARGB fans for unmatched cooling performance. The interconnecting fan blades have been designed with a balanced P/Q curve suitable for both air and liquid cooling.
TUBE CLIPS INCLUDED
ECO-FRIENDLY PACKAGING WITH ENHANCED PROTECTION
USING EPDM + IIR COMPOSITE MATERIALS
Specificaties
  • Product Number MLY-D36M-A24PZ-RW
  • Exterior Color White
  • Radiator Material Aluminum
  • Radiator Dimensions 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Tube Length 420 mm / 16.5 inch
  • Pump Profiles Addressable Gen2 RGB
  • Pump Dimensions 88.3 x 83.6 x 65.7 mm / 3.5 x 3.3 x 2.6 inch
  • Pump Speed 3000 RPM ± 10%
  • Pump MTTF >210,000 Hours
  • Pump Noise Level 20 dBA
  • Pump Connector 4-Pin + SATA
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 6.75 W
  • Fan Quantity 3 PCS
  • Fan LED Type Addressable Gen 2 RGB
  • Fan Speed 0-2400 RPM ± 10%
  • Fan Airflow 75.2 CFM (Max)
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.18A
  • Fan Safety Current 0.35A
  • Warranty 6 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Pro
