MasterFan Pro 140 Air Pressure image number 0
MasterFan Pro 140 Air Pressure image number 1
MasterFan Pro 140 Air Pressure image number 2
MasterFan Pro 140 Air Pressure image number 3
Select Your Silence
Specificaties
  • Accessory 4x Tap Screw
  • Cooler Type Case Fan
  • Warranty 5 years
  • Fan Size 140
  • LED Lighting Non-LED
  • LED Non-LED
  • Fan Power Consumption 1.08W - S Mode (Silent)
  • Fan Life Expectancy 490,000 Hours
  • Fan Power Consumption 1.8W - Q Mode (Quiet)
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Series MasterFan Pro
  • Fan Power Consumption 3W - P Mode (Performance)
  • Fan Weight 172g
  • Fan Rated Current 0.09A - S Mode (Silent)
  • Fan Rated Current 0.15A - Q Mode (Quiet)
  • Fan Rated Current 0.25A - P Mode (Performance)
  • EAN code 4719512052600
  • UPC code 884102028717
  • Fan Noise Level 6-20 dBA - S Mode (Silent)
  • Fan Noise Level 6-30 dBA - Q Mode (Quiet)
  • Fan Noise Level 6-36 dBA - P Mode (Performance)
  • Product Number MFY-P4NN-15NMK-R1
  • Fan Air Pressure 1.59 mmH2O ± 10% - S Mode (Silent)
  • Fan Speed 650-1550 RPM ± 10% - S Mode (Silent)
  • Fan Speed 650-2200 RPM ± 10% - Q Mode (Quiet)
  • Fan Air Pressure 3.15 mmH2O ± 10% - Q Mode (Quiet)
  • Fan Air Pressure 5.28 mmH2O ± 10% - P Mode (Performance)
  • Fan Speed 650-2800 RPM ± 10% - P Mode (Performance)
  • Fan Airflow 46.2 CFM ± 10% - S Mode (Silent)
  • Fan Airflow 64.2 CFM ± 10% - Q Mode (Quiet)
  • Fan Airflow 82.2 CFM ± 10% - P Mode (Performance)
