MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 0
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 1
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 2
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 3
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 4
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 5
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 6
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 7
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 8
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 9
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 10
MasterFan Pro 140 Air Flow RGB 3 in 1 with RGB LED Controller image number 11
Cool with Your Color
Specificaties
  • RGB LED Controller - Dimensions 90 x 53 x 14 mm / 3.54 x 2.08 x 0.55 inch
  • RGB LED Controller - LED Connector 4 Ports
  • RGB LED Controller - Interface 9-Pin USB 2.0 Connectors
  • RGB LED Controller - Power Connector SATA Power
  • RGB LED Controller - Software Yes
  • RGB LED Controller - Accessory 450mm RGB LED Extension Cable x 4
  • Legacy Cooling
  • Fan Profiles RGB
  • RGB LED Controller - Accessory 600mm USB 9 Pin Extension Cable x 1
  • Cooler Type Case Fan
  • RGB LED Controller - Accessory Metal Screw x 12
  • Fan Noise Level 6 - 20 dBA
  • Fan Profiles Blue
  • Warranty 5 years
  • Fan Profiles Red
  • Fan Safety Current 0.4A
  • Fan L-10 Life 70,000 Hours
  • Fan MTTF 490,000 Hours
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Series MasterFan Pro
  • Fan Rated Current 0.18A
  • Fan Speed 500-800 RPM ± 10%
  • Fan Power Consumption 3.84W
  • Fan Air Pressure 0.54 mmH2O ± 10%
  • Fan Weight 172g
  • Fan Airflow 53 CFM ± 10%
  • EAN code 4719512060506
  • UPC code 884102033162
  • Product Number MFY-F4DC-083PC-R1
