MasterBox NR200P V2 image number 0
MasterBox NR200P V2 image number 1
MasterBox NR200P V2 image number 2
MasterBox NR200P V2 image number 3
MasterBox NR200P V2 image number 4
MasterBox NR200P V2 image number 5
MasterBox NR200P V2 image number 6
MasterBox NR200P V2 image number 7
MasterBox NR200P V2 image number 8
MasterBox NR200P V2 image number 9
MasterBox NR200P V2 image number 10
MasterBox NR200P V2 image number 11
MasterBox NR200P V2 image number 12
MasterBox NR200P V2 image number 13
MasterBox NR200P V2 image number 14
MasterBox NR200P V2 image number 15
MasterBox NR200P V2 image number 16
MasterBox NR200P V2 image number 17
MasterBox NR200P V2 image number 18
MasterBox NR200P V2 image number 19
MasterBox NR200P V2 image number 20
MasterBox NR200P V2 image number 21
MasterBox NR200P V2 image number 22
MasterBox NR200P V2 image number 23
MasterBox NR200P V2 image number 24
MasterBox NR200P V2 image number 25
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
MasterBox NR200P V2
Grote mogelijkheden, klein formaat
MasterBox NR200P V2
Compact maar krachtig
Blijf koel onder druk
Geoptimaliseerde GPU-prestaties
Uitgebreide GPU-ondersteuning
Eenvoudige toegang zonder gereedschap
Ondersteuning voor USB 3.2 Gen 2x2 Type C
Vernieuwde NCORE-stijl
Kleur
Nu kopen
Koelsysteem
240-280MM
VLOEISTOFKOELERS
18,25 L
ULTRASTRAK ONTWERP
Extra Cool
120MM
ONDERSTE VENTILATOR
UITGEBREIDE GPU-ONDERSTEUNING
Inclusief opties voor verticale montage, een aangepaste PCIe 4.0 riser-kabel en een steunbeugel voor GPU's tot 356mm lang en 160mm hoog.
Specificaties
  • Modelnummer MasterBox NR200P V2: NR200PV2-KCNN-S00, MasterBox NR200P V2 White: NR200PV2-WCNN-S00
  • Externe kleur Black, White / Grey
  • Materialen - Buitenkant SGCC Steel, Mesh, ABS Plastic
  • Materialen - Linkerzijpaneel Tempered Glass x1, Steel x1
  • Afmetingen (L x B x H) 372 x 185 x 292mm (incl. Protrusions), 360 x 185 x 274mm (excl. Protrusions)
  • Volume 18.25L
  • Ondersteuning moederbord Mini-ITX, Max. size: 170 x180mm
  • Uitbreidingsslots 3
  • 5.25" drivebays 0
  • 3.5" schijfhouders 1 (Max. 2, remove bottom fan)
  • 2.5" / 3.5" drivebays (combi) 1
  • 2.5" schijfcompartimenten 1 (Max. 2)
  • I/O-paneel - USB-poorten 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen 2x2 Type C
  • I/O-paneel - Audio In / Uit 1x 3.5mm Headset Jack (Audio+Mic)
  • Meegeleverde accessoires 1x PCIe 4.0 x16 riser cable, 1x GPU Holder
  • Voorgeïnstalleerde ventilatoren - Boven N/A
  • Voorgeïnstalleerde ventilatoren - Voorkant N/A
  • Voorgeïnstalleerde ventilatoren - Achter N/A
  • Voorgeïnstalleerde ventilatoren - Onder 1x 120mm 650~1800rpm PWM SickleFlow
  • Ventilatorondersteuning - Boven 2x 120/140mm
  • Ventilatorondersteuning - Zijkant N/A
  • Ventilatorondersteuning - Achter N/A
  • Ventilatorondersteuning - Onder 2x 120mm (1x max 15mm, w/o 3.5" HDD at the bottom)
  • Radiatorondersteuning - Boven 120 / 140 / 240 / 280mm
  • Radiatorondersteuning - Zijkant N/A
  • Radiatorondersteuning - Achter N/A
  • Radiatorondersteuning - Onder N/A
  • Vrije ruimte - CPU-koeler 67mm
  • Ruimte - PSU 130mm
  • Ruimte - GPU Exceed front bracket: L: 357mm (incl. power connector) , H: 160mm (incl. power connector) , W: 73mm (triple slot); Not exceed front bracket: L: 334mm (incl. power connector) , H: 160mm (incl. power connector) , W: 80mm (triple slot)
  • Stoffilters Bottom, Left, Right, Top Panels
  • Ondersteuning voor voeding SFX, SFX-L
  • Garantie 2 years
  • Serie MasterBox Series
  • Maat Mini ITX
