Mondiaal hoofdkantoor
Nr. 398, Xinhu 1st Rd, Neihu District, Taipei City, 114, Taiwan
Natural Aesthetics. Immersive View. Advanced Cooling.
The Elite 690 features dual tempered glass panels to showcase your build, while a wood-textured front accent and mesh intake blend warmth with airflow efficiency. With top and bottom ventilation for vertical cooling, it supports versatile fan and radiator setups—perfect for performance-driven or style-focused builds.
Beveled glass panels create an immersive, seamless showcase of your build.
Vertical layout separates thermal zones for better airflow and cleaner cable routing.
Up to 10 fans in a bottom-to-top layout maximize airflow and cooling.
Crafted from real wood, the front panel adds a warm, organic touch to any space.
Top 360mm and side 240mm radiator support for powerful cooling setups.
Includes 3 daisy-chainable ARGB fans with full motherboard lighting sync support.
Mesh panels ensure enhanced airflow and system-wide thermal performance.
Supports up to 425mm GPUs—ready for RTX 50 Series and beyond.
USB 3.2 Gen 2x2 Type-C and dual USB 3.0 ports for blazing-fast connectivity.![]()
