CK570 SF6 Chun-Li Gaming Keyboard image number 0
CK570 SF6 Chun-Li Gaming Keyboard image number 1
CK570 SF6 Chun-Li Gaming Keyboard image number 2
CK570 SF6 Chun-Li Gaming Keyboard image number 3
CK570 SF6 Chun-Li Gaming Keyboard image number 4
CK570 SF6 Chun-Li Gaming Keyboard image number 5
CK570 SF6 Chun-Li Gaming Keyboard image number 6
The Cooler Master CK570 Mechanical Keyboard is the ultimate customizable keyboard for gamers.
Special Edition
Cooler Master
x Capcom Street Fighter 6
The CH331 SF6 CHUN-LI headset, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's audio expertise,
embodying the spirit of Chun-Li.
Keyswitch
CHERRY
MX SWITCHES
Durable
PBT double-injection keycaps with side print
Made of a high quality PBT doubleshot construction process which prevents the fonts from fading while allowing for RGB backlighting to shine through
*PBT is only for US and TC layouts
Take control with a precision dial
Three-way precision dial enables you to adjust volume, cycle through color modes, and more — all customizable via our MasterPlus+ software.
Improved Ergonomics
TWO-STEP KICKSTAND
Adjustable feet improves the ergonomics of the CK570 by letting you control the angle of the keys to reduce wrist strain.
Specificaties
  • Product Number CK-570-MCCR1-US
  • Keyboard Switch Type Cherry MX Red
  • Keyboard Keycaps PBT Double shot keycaps with Laser print
  • Layout ANSI: 98Key layout, ISO: 99Key layout
  • Keyboard Material Plastic / Nature Rubber / Silicone
  • Keyboard Color Street Fighter 6 Chun-Li Edition
  • Keyboard LED Color RGB, 16.7 million colors
  • Keyboard Response Time 1ms
  • On-board Memory 512KB
  • On-the-fly System Yes
  • Keyboard Multimedia Key Through Function Key (FN)
  • Connectivity Wired with detachable Type-C cable
  • Charging N/A
  • Battery N/A
  • Compatible OS Windows 8+ / Mac OS X 10.10+
  • Software Support MasterPlus+ / MasterCTRL Support
  • Keyboard Connector Cable USB Type-C (Keyboard Side), USB 2.0 Type A (Computer Side)
  • Keyboard Cable 1.8m, USB Type-C Detachable & Coiled Braided
  • Keyboard Dimensions (L x W x H) Standard: 380.89 x 140.42 x 38.74 mm, Feet Open 1: 380.89 x 140.42 x 42.9 mm, Feet Open 2: 380.89 x 140.42 x 45.51 mm
  • Keyboard Weight 956g / 2.108 lbs (without cable)
  • Product Keyboard
