Caliber X1 Gaming Chair image number 0
Caliber X1 Gaming Chair image number 1
Caliber X1 Gaming Chair image number 2
Caliber X1 Gaming Chair image number 3
Caliber X1 Gaming Chair image number 4
Caliber X1 Gaming Chair image number 5
A Throne to Rule All Games
Cooler Master Caliber X1 is designed for ultra comfort and style that enhances your game.
Nu kopen
Specificaties
  • Product Number CMI-GCX1-2019
  • Color Black
  • Total Height Range 130-138 cm / 51.2"-54.3"
  • Backrest Length 86cm / 33.9"
  • Backrest Width 58 cm / 22.8"
  • Armrest to Armrest 72 cm / 28.3"
  • Seat Width (including sides) 54 cm / 21.3"
  • Seat Depth 54 cm / 21.3"
  • Diameter of Base 70 cm / 27.6"
  • Metal Plate Thickness 1.5 mm
  • Armrest Adjustability 30-37 cm / 11.8"-14.6"
  • Floor to Seat Top 50-58 cm / 19.7"-22.8"
  • Height Adjustability 8 cm / 3.1"
  • Armrest Width Adjustability 1.5 cm / 0.6"
  • Recline 90-180 degree
  • Armrest 4D (lift, sway, swivel, forward)
  • Headrest Ergonomic Pillow
  • Extra Padded Backrest Built-in pillow (hidden stripes)
  • Inner Material Molded Foam
  • Frame Material Steel
  • Base (leg) Aluminum
  • Caster 75 mm / 3.0"
  • Gas Lift Class 4
  • Net Weight 24.7 kg / 54.5 lbs
  • Gross Weight 29.0 kg / 63.9 lbs
  • Max. Weight Load 150 kg / 330 lbs
  • Product Gaming Chair
  • Chair Type Caliber X1 Series
