MasterLiquid PL360 Flux 30th Anniversary Edition image number 0
MasterLiquid PL360 Flux 30th Anniversary Edition image number 1
MasterLiquid PL360 Flux 30th Anniversary Edition image number 2
MasterLiquid PL360 Flux 30th Anniversary Edition image number 3
MasterLiquid PL360 Flux 30th Anniversary Edition image number 4
The PL360 Flux 30th Anniversary Edition is the new embodiment of enhanced performance cooling.
Cooler Master is releasing a limited version of the MasterLiquid Flux Series flagship liquid cooler to represent 30 years of success. The performance liquid cooler features the new Mobius Series 30th Anniversary Edition fans, exclusive pump cover with the 30th Anniversary logo, as well as unique limited edition print on the radiator. The PL360 Flux 30TH Anniversary Edition has refined performance from fans to the copper base, as well as unique aesthetic design to represent our decades worth of innovation.
Slim & Sleek Radiator
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
Superior Performance Ratio
Precision engineered ultra-thin spaded fins maximize microchannels accurately to target heat spots. The enlarged copper base surface optimized with ideal base thickness accelerates heat transfer.
Dual Chamber Pump
Dual Chamber Pump
The compact Dual Chamber pump delivers the perfect balance of waterflow and pressure, decorated with the 30th Anniversary logo.
Ultimate Heat Exchange
A high speed motor utilizing a ceramic bearing impeller, which forces balanced waterflow to and from the radiator for ultimate efficiency of heat exchange.
  • 產品型號 MLY-D36M-A23PZ-30​
  • 外觀顏色 黑色
  • CPU 腳位 Intel® LGA 1700 / 1200 / 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 socket
  • CPU 腳位 AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 / TR4 socket
  • 水冷排材質
  • 水冷排尺寸 394 x 119.6 x 27.2 mm
  • 幫浦尺寸 89 x 75 x 40 mm
  • 幫浦使用壽命 >210,000 小時
  • 幫浦噪音等級 15 dBA (最大)
  • 幫浦連接器 4-Pin
  • 幫浦額定電壓 12 VDC
  • 幫浦功耗 6W
  • 風扇數量 3 個
  • 風扇 LED 類型 Addressable Gen 2 RGB
  • 風扇轉速 0-2400 RPM ± 10%
  • 風扇風量 75.2 CFM (最大)
  • 風扇噪音水平 30 dBA (最大)
  • 風扇壓力 3.63 mmH₂O (最大)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇平均故障間隔 >200,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.18A
  • 風扇安全電流 0.35A
  • 專利號 US10739084B2, US11061450B2, US10409341B2, US11320874B2, US11474574B2
  • 產品保固 5年
  • 產品類型 CPU水冷散熱器
  • 系列 MasterLiquid Pro
  • 水冷排尺寸 360
