Ports & Slots
USB 3.2 Gen 2 Type C Support
USB 3.2 Gen 2 Type C port built into the I/0 panel allows multi-purpose, streamlined data transmission.
TD500 Mesh V2’s iconic polygonal design paired with included three 120mm ARGB fans engulfs your system in an ever-changing glow
Polygonal FineMesh Features a 3D contour and is also capable of simultaneously providing high airflow and dust filtration.
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
Ports & Slots
The top panel is entirely removable for improved access during
assembly and ease of mounting of cooling solutions.
MasterBox TD500 Mesh V2 is natively compatible with ITX, M-ATX and ATX motherboards.
E-ATX motherboards such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
Support for 7x 120mm fans and 360mm front and top radiator support ensure that performance is not compromised.
Featuring a tempered glass side panel with Street Fighter character elements, completely toolless for quick access to the internals.
MasterBox TD500 Mesh V2's removable PSU cover allows users to freely decide whether to showcase or keep their PSUs hidden.
