MasterBox 520 Mesh ARGB ATX 機殼 image number 0
MasterBox 520 Mesh ARGB ATX 機殼 image number 1
MasterBox 520 Mesh ARGB ATX 機殼 image number 2
MasterBox 520 Mesh ARGB ATX 機殼 image number 3
MasterBox 520 Mesh ARGB ATX 機殼 image number 4
MasterBox 520 Mesh ARGB ATX 機殼 image number 5
MasterBox 520 Mesh ARGB ATX 機殼 image number 6
MasterBox 520 Mesh ARGB ATX 機殼 image number 7
MasterBox 520 Mesh ARGB ATX 機殼 image number 8
MasterBox 520 Mesh ARGB ATX 機殼 image number 9
MasterBox 520 Mesh ARGB ATX 機殼 image number 10
MasterBox 520 Mesh ARGB ATX 機殼 image number 11
MasterBox 520 Mesh ARGB ATX 機殼 image number 12
MasterBox 520 Mesh ARGB ATX 機殼 image number 13
才貌雙全、風華絕代
MasterBox 520 Mesh可以滿足各種新穎需求的遊戲玩家或資深老手等完美機殼的設計
Performance
FINEMESH PERFORMANCE FRONT PANEL
Large mesh intakes offer unrestricted airflow and stellar thermals for demanding systems.
Colors
AVAILABLE IN BOTH BLACK & WHITE
Choose the color that best matches your setup!
Design
Removable Top Panel
The top panel is entirely removable for improved access and easy installation of cooling solutions such as fans and radiators.
Fans
Three CF120 ARGB Fans Included
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
Screwless & Tool-Free TG Side Panel
The tempered glass side panel is secured with pins for easy removal, facilitating quick, easy installation.
Versatile Cooling Options
Customization
Supports up to seven 120mm fans and dual 360mm radiators on the top 140mm and front panel.
Hardware Compatibility
MasterBox 520 Mesh is natively compatible with ITX, M-ATX and ATX motherboards.
E-AT motherboards, such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
  • 產品型號 MasterBox 520 Mesh: MB520-KGNN-S00, MasterBox 520 Mesh White: MB520-WGNN-S00
  • 外觀顏色 黑色, 白色
  • 材質 - 外部 Mesh, Steel, ABS Plastic, Tempered Glass
  • 材質 - 左側板 鋼化玻璃
  • 尺寸 (長x寬x高) 499 x 210 x 498mm (Incl. Protrusions), 430 x 210 x 479mm (Body size)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, SSI-CEB, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • PCI 擴充槽 7
  • 3.5" 硬碟架 2
  • 2.5" 硬碟架 3
  • I/O 面板 - USB 埠 1x USB 3.2 Gen 1 Type A, 1x USB 3.2 Gen 2 Type C
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • I/O 面板 - 其他 1x Reset/ARGB button
  • 包含配件 ARGB 風扇集線器
  • 預裝風扇 - 上方
  • 預裝風扇 - 前方 3x CF120 ARGB
  • 預裝風扇 - 後方 N/A
  • 風扇支援 - 上方 3x 120mm, 2x 140mm
  • 風扇支援 - 前方 3x 120mm, 2x 140mm
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 上方 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • 水冷支援 - 前方 120 / 140 / 240 / 280 / 360mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 165mm
  • 預留安裝空間 - 電源供應器 200mm (Recommended up to 170mm)
  • 預留安裝空間 - 顯示卡 410mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 MasterBox 系列
