Hyper H411R image number 0
Hyper H411R image number 1
Hyper H411R image number 2
Hyper H411R
Hyper H411R
Hyper H411R
精巧塔型散熱器
Hyper H411R
作為市場長青樹 Hyper 系列的新成員,Hyper H411R 是一款平價、小巧且高性能的空冷散熱器。其緊湊的散熱片設計適合用在小型主機。搭載 4 隻熱導管與直觸式技術,帶來比上一代 Hyper 103 更好的散熱效能表現。特殊散熱片設計能有效最佳化熱導管前方的氣流。
The Hyper H411R is an affordable, compact and high performance air cooler that is a great fit for small form factor system. With 4 heatpipes and Direct Contact technology, this outperforms its predecessor Hyper 103. The special fin design optimizes air flow toward heatpipes. Its 92mm PWM fan features a wide fan speed range and can be fine tuned for maximum airflow and cooling performance or silent operation.
4 Direct Contact Heatpipes
Performance in Compact Size
Easy Installation
Tool-free mounting system ensures hassle-free installation. Universal retention brackets are compatible with latest Intel and AMD socket CPU.
Perfecting the Heatsink Design
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
With height of 136.5mm, the Hyper H411R is a compact tower cooler, designed to fit in tight builds. With its outstanding performance in its class, it is a great solution for Micro ATX and Mini ITX boards.
Just like the Hyper 212, it includes 4 Direct Contact heatpipes constructed out of copper to accelerate the heat conduction through the entire heatpipe. This allows heat to be dissipated quickly and efficiently throught the funnel shaped aluminum fins.
PERFECTING THE HEATSINK DESIGN
Cooler Master's years of aluminum fin craftmanship is second to none. Optimized fin stacked distance between each layer is based on stringent airflow tests from our labs. As a result, even with a compact-size each heatsink with the 92mm fan is able to maintain performance in a compact build.
EASY INSTALLATION
EASY INSTALLATION
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • 產品型號 RR-H411-20PW-R1
  • 顏色 銀色
  • CPU 腳位 Intel® LGA 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • CPU 腳位 AMD® AM5 / AM4 Socket
  • 尺寸 (長 x 寬 x 高) 102 x 84.5 x 136 mm
  • 散熱器材質 4根熱管 / 直觸 / 鋁製散熱片
  • 風扇尺寸 (長 x 寬 x 高) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • 風扇設定檔 White
  • 風扇數量 1 個
  • 風扇轉速 600-2000 RPM (PWM) ± 10%
  • 風扇風量 34.73 CFM (最大)
  • 風扇風壓 1.86 mmH₂O (最大)
  • 風扇平均故障間隔 >40,000 小時
  • 風扇噪音水平 29.38 dBA (最大)
  • 風扇軸承類型 來福軸承 (Rifle Bearing)
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.19A
  • 風扇安全電流 0.4A
  • 風扇功耗 2.28W
  • 產品保固 2年
  • 產品類型 CPU空冷散熱器
  • 系列 Hyper
  • 熱導管數量 4
  • 說明 新的包裝中包含AM5和LGA 1700安裝扣具。您可以透過CM商店、地區經銷商或分銷商獲得舊產品所需的安裝扣具。不再支援舊的CPU插座(LGA 2066、LGA2011-v3、LGA2011、LGA1366、AM3+、AM3、AM2+、AM2、FM2+、FM2、FM1)。
