GM27QP image number 0
GM27QP image number 1
GM27QP image number 2
GM27QP image number 3
GM27QP image number 4
GM27QP image number 5
GM27QP
GM27QP
GM27QP
GM27QP
GM27QP
GM27QP
The Competitive Choice for Work and Play
GM27QP
Workers and Players Unite
The GM27QP is meticulously crafted for universal appeal, delivering exceptional value and performance. With its QHD resolution, it enriches your work and play experiences by offering a wide DCI-P3 color gamut, all seamlessly displayed at a remarkable 240Hz refresh rate.
Details Aplenty
The QHD resolution with curved display not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive. No matter how you spend your time at your PC, the GM27QP has you covered whether it be for work or for fun.
Details Aplenty
Details Aplenty
Stunning Image Quality
With incredible color detail, the GM27QP not only covers 90% of DCI-P3 but also supports sRGB, Adobe RGB, and NTSC, making it a great choice for color-sensitive work.
Experience Better Gaming Sessions
With Adaptive Sync, GM27QP offers tear-free and extra smooth gameplay for more immersive experience.
Built-In Dual Speakers
Experience sound entertainment with 2 built-in speakers- no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
Always On Demand
Always On Demand
A built-in game assist function includes several settings to fine tune your in-game performance.
  1. Crosshair functionality : The crosshair feature ensures your every shot is accurate and precise, allowing gamers to always enjoy perfect aim.
  2. FPS Counter : You can keep track of your performance with a real-time, on-screen FPS counter. Ensure you experience no slowdown so you can keep your head in the game.
  3. Black Stabilization : Black stabilization ensures accurate colors and visuals during particularly dark scenes, so you never miss a beat.
Multiple Connections
Connect your devices with I/O ports consisting of:
• DP1.4 x 1
• HDMI2.0 x 2
• 3.5 mm Audio Out
• Power
Eye-Friendly Comfort
  • 產品型號 CMI-GM27QP
  • 長寬比 16:9
  • 螢幕尺寸 27"
  • 面板類型 曲面系列
  • 面板 VA 1.07B (8 Bit+FRC)
  • 解析度 2K QHD 2560x1440
  • 更新率 240 Hz
  • 對比度 2500:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 400 nits
  • HDR HDR400
  • HDR Peak 亮度 N/A
  • 調光分區 N/A
  • 色域 DCI-P3 90% (Typ., CIE 1931), Adobe RGB 84% (Typ., CIE 1931), sRGB 120% (Typ., CIE 1931), NTSC 85% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - DP 1.4 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 3.5mm 音源輸出 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms MPRT, 1ms GtG (OD)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 支援
  • 介面 (輸入/輸出) - 喇叭 2 (2W)
  • KVM N/A
  • PIP/PBP (畫面分割) 支援
  • 燈光 N/A
  • 功耗 65W (Max)
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 ±15°
  • 高度調整範圍 130mm
  • 支架調整範圍 N/A
  • Cooler Master 散熱設計 N/A
  • 產品分類 電競螢幕
  • 螢幕系列 GM系列
  • Panel Type VA
