MasterLiquid 120L Core CPU Liquid Cooler image number 0
MasterLiquid 120L Core CPU Liquid Cooler image number 1
MasterLiquid 120L Core CPU Liquid Cooler image number 2
Cooler Master is building upon the success of the MasterLiquid Lite Series with a redesigned and improved release of the MasterLiquid 120L Core.
Cooler Master has built upon the classic MasterLiquid L Series to present a redesigned and improved release of the MasterLiquid 120L Core. Featuring new design elements that bring a classic minimalist look to the series, the MasterLiquid 120L Core represents Cooler Master’s ongoing innovative spirit.
Gen S Dual Chamber Pump
Redesigned copper base targets heat spots with precision along with boosted water flow and pressure for enhanced cooling performance.
Expanded Radiator Surface
Expanded radiator fin surface accelerates heat dissipation for superior cooling.
120mm fan
An upgraded 120mm fan delivers optimal radiator performance.
Clean Classic Design
Clean minimalist design brings a refreshed modern facelift to the pump cover.
CryoFuze thermal PASTE
Includes premium CryoFuze thermal paste for exceptional heat conductivity.
  • 產品型號 MLW-D12M-A17PK-R1
  • 外觀顏色 黑色
  • CPU 腳位 Intel® LGA 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • CPU 腳位 AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • 水冷排材質
  • 水冷排尺寸 157 x 119.6 x 27.2 mm
  • 幫浦尺寸 81 x 76 x 47 mm
  • 幫浦使用壽命 >70,000 小時
  • 幫浦噪音等級 12 dBA (最大)
  • 幫浦連接器 3-Pin
  • 幫浦額定電壓 12 VDC
  • 幫浦功耗 3.96W
  • 風扇數量 1 個
  • 風扇轉速 650-1750 RPM ± 10%
  • 風扇風量 71.93 CFM (最大)
  • 風扇噪音水平 27.2 dBA (最大)
  • 風扇壓力 1.86 mmH₂O (最大)
  • 風扇軸承類型 來福軸承 (Rifle Bearing)
  • 風扇平均故障間隔 >160,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.26A
  • 風扇安全電流 0.37A
  • RAM Clearance N/A
  • 產品保固 3 年
  • 系列 MasterLiquid Lite
  • 產品類型 CPU水冷散熱器
  • 水冷排尺寸 120
