GA2711 Gaming Monitor image number 0
GA2711 Gaming Monitor image number 1
GA2711 Gaming Monitor image number 2
GA2711 Gaming Monitor image number 3
GA2711 Gaming Monitor image number 4
GA2711 Gaming Monitor image number 5
GA2711 Gaming Monitor image number 6
GA2711 Gaming Monitor image number 7
GA2711 Gaming Monitor image number 8
GA2711 Gaming Monitor image number 9
GA2711 Gaming Monitor image number 10
Dive Into The Gaming World
The GA2711 is designed for game players who want to enjoy the entry refresh rate experience.
DETAILS APLENTY
DETAILS APLENTY
The QHD resolution not only offers sharper visuals, but also provides ample screen space, making multitasking a breeze and gaming more immersive.
EXPERIENCE BETTER GAMING SESSIONS
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
SPEED AND PRECISION
The 100Hz refresh rate and a 1ms (MPRT) response time reduces both motion blur and smearing- whether you are gaming, working or watching movies.
1300:1 contrast ratio
REALISTIC IMAGE QUALITY 99% SRGB
With optimal color detail and a color gamut covering 99% of SRGB, these monitors are excellent for color-sensitive work, enhancing images with more vivid and vibrant colors.
  • 產品型號 CMI-GA2711
  • 螢幕尺寸 27"
  • 長寬比 16:9
  • 面板類型 平面系列
  • 面板 IPS 16.7M (8 Bit)
  • 解析度 2K QHD 2560x1440
  • 更新率 100 Hz
  • 對比度 1300:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 250 nits (Typical)
  • HDR HDR10
  • HDR Peak 亮度 250 nits (Typ.)
  • 調光分區 N/A
  • 色域 DCI-P3 75% (Typ., CIE 1976), Adobe RGB 78% (Typ., CIE 1931), sRGB 99% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - DP 1.4 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 3.5mm 音源輸出 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT), 4ms (GtG)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 支援
  • 介面 (輸入/輸出) - 喇叭 N/A, (2W*2 可選購)
  • KVM N/A
  • PIP/PBP (畫面分割) N/A
  • 燈光 N/A
  • 功耗 28W (最大)
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 N/A
  • 高度調整範圍 N/A
  • 支架調整範圍 N/A
  • Cooler Master 散熱設計 N/A
  • 產品分類 電競螢幕
  • 螢幕系列 GA系列
  • Panel Type IPS
