PL360 SPR Edition CPU Liquid Cooler image number 0
PL360 SPR Edition CPU Liquid Cooler image number 1
PL360 SPR Edition CPU Liquid Cooler image number 2
PL360 SPR Edition CPU Liquid Cooler image number 3
PL360 SPR Edition CPU Liquid Cooler image number 4
Introducing the PL360 SPR Edition, our new cooling workhorse designed to power through the toughest tasks you will tackle in your day to day
 Certified by INTEL
Certified by INTEL
Introducing Cooler Master’s PL240/360 SPR Edition, our new cooling workhorse designed to power through the toughest tasks you will tackle in your day to day, in tandem with Intel’s latest Xeon Platinum Processor. The PL240/360 hhas been designed specifically for the Xeon and is Intel-certified to be exclusively compatible with its LGA 4677 sockets. Power up your workstation with the ultimate cooler-processor duo.
Learn More
 Large, full-coverage copper base
An extra-large copper base ensures rapid heat transfer while a double impeller brings more powerful water flow for quick heat dissipation to ensure your workflow is never interrupted.
 Industrial-grade structural design
Industrial-grade structural design provides a fully sealed chamber and totally stable operation, for whisper quiet operation that won’t distract or derail your productivity.
 Double Impeller
Double Impeller
A double impeller strengthens water flow, again reinforcing heat dissipation for that extra cooling oomph when you’re pushing your machine to the limits with multiple applications and complex tasks.
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
ข้อมูลจำเพาะ
  • Product Number MLO-D36M-A24PK-R1
  • Exterior Color Black
  • CPU Socket LGA4677
  • Waterblock Dimensions 118 x 78 x 24.7 mm / 4.6 x 3.1 x 1.1 inch
  • Radiator Material Aluminum
  • Radiator Dimensions 394 × 119 × 27.2 mm / 15.5 × 4.7 × 1.1 inch
  • Pump MTTF >198,000 Hours
  • Pump Connector 4-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 7W
  • Dimensions (L x W x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
  • Fan Quantity 3 PCS
  • Fan LED Type Non-LED
  • Fan Speed 0-2050 RPM ± 10%
  • Fan Airflow 63.1 CFM (Max)
  • Fan Noise Level 22.6 dBA (Max)
  • Fan Pressure 2.69 mmH₂O (Max)
  • Fan MTTF >200,000 Hours
  • Fan Rated Current 0.12A
  • Fan Safety Current 0.35A
  • RAM Clearance N/A
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Cooler Type Workstation Cooler
  • Radiator Size 360
