• Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
      • MasterHUB
        MasterHUBMasterHUB
        • MAX
          MAXMAX
          • ATX
          • Mini ITX
        • Immersive Experience
          Cooling
          360 DEGREES OF COOL
          PC Cases
          Premium Modular ATX Case
          Power Supplies
          PRECISE SILENT POWER
          Furniture
          RELAXATION AT YOUR COMMAND
          Systems
          COOL. COMPACT. QUIET.
          MAX
        • Builder's Zone
          Builder's Zone
          • PSU Calculator
          • CPU Compatibility
          • Guide & Resources
          Builder's Zone
        • Software
          Software
          • MasterHUB
          • Masterplus+
          • Masterctrl
          Software
        • Support
          Support
          • Product registration
          • Tech support
          • Warranty
          • Warranty check
          • Faq
          • Contact us
          Support
          Special Announcement
        Mobius 120P ARGB 3-pack Fan Kit
        Overview
        1. Home/
        2. Cooling/
        3. Case Fans/
        4. Mobius 120P ARGB 3-pack Fan Kit
        More Balance, More Burst
        • Ring Blade Design (RBD)
        • Pressure Air Acceleration
        • Absolute Acoustics
        • Luminescent Light Effects
        • Addressable Gen 2 RGB
        • New Mini A1 controller
        PERFECTING ENGINEERING
        Cooler Master’s Mobius 120P ARGB is a part of our highest performing series of fans. With an innovative ring blade design, the Mobius series optimizes for both performance and acoustics. Catering to a wide range of applications, cases, and cooling set ups, the Mobius 120P can suit the needs of any build.
        RING BLADE DESIGN (RBD)
        LOOP DYNAMIC BEARING
        OIL REFLOW
        ANTI-SWAY SYSTEM
        DUST PROOFING
        PRESSURE AIR ACCELERATION
        An angled inner frame rim with chamfered side vents boosts air intake, maximizes air flow, and eliminates dead spots.
        ABSOLUTE ACOUSTICS
        Sound output fine tuned to the optimal prominence ratio to achieve sub 6dB noise levels without performance sacrifice.
        Acoustic Testing
        Anechoic Chamber for ISO 3745
        • Sound Pressure: IS0-7779
        • Sound Power: ISO-7779
        ANTI-VIBRATION DAMPER
        Our Achievements
        10
        AWARDS
        Addressable Gen 2 RGB syncs with Cooler Master’s MasterPlus+ software and dedicated controller, allowing customization of individual LED colors, effects, brightness and more – all from an intuitive, convenient interface.
        (controller sold separately)
        NEW MINI A1 ARGB CONTROLLER
        The brand new mini A1 controller is small, convenient, and easily allows you to daisy chain and connect up to three Mobius 120P fans. Compatible with our MasterPlus software, it allows full customization, all the way down to individual LED effects, brightness, and more.
        Trending
        New
        MasterFrame 600
        Discover
        • About
          Corporate
          Social Media
          News
          Events
        • Support
          Product Registration
          Tech Spec
          Warranty
          Warranty check
          Faq
          Contact us
        CAREER
        RESOURCE CENTER
        • Privacy policy
        • Terms of use
        • Cookie policy
        • Conformity of products
        Confirm your Country
        It seems you are from สหรัฐอเมริกา
        The page you're looking shows Cooler Master contents for ไทย.
