สำนักงานใหญ่ระดับโลก
เลขที่ 398 ถนน Xinhu 1st เขตเน่ยหู เมืองไทเป 114 TWN
Cooler Master has redesigned the innovative Thermoelectric Cooling (TEC) solution with the launch of the new MasterLiquid ML360 SUB-ZERO EVO.
Powered by Intel® Cryo Cooling Technology with integrated software to allow customizable overclocking catered to your specific needs.
The redesigned TEC unit within the water block accelerates cooling to deliver maximum overclocking of your Intel® processor.
Low profile radiator with superior fin density coupled with performance fans dissipates heat rapidly.
Compact DIY pump upgraded with silent IC delivers better noise performance with small footprint.
