สำนักงานใหญ่ระดับโลก
เลขที่ 398 ถนน Xinhu 1st เขตเน่ยหู เมืองไทเป 114 TWN
SIMPLE YET POWERFUL
ERGOSTAND IV
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
