Tempest GZ2711 Gaming Monitor image number 0
Tempest GZ2711 Gaming Monitor image number 1
Tempest GZ2711 Gaming Monitor image number 2
Tempest GZ2711 Gaming Monitor image number 3
Tempest GZ2711 Gaming Monitor image number 4
Tempest GZ2711 Gaming Monitor image number 5
Tempest GZ2711 Gaming Monitor image number 6
Tempest GZ2711 Gaming Monitor image number 7
Tempest GZ2711 Gaming Monitor image number 8
Tempest GZ2711 Gaming Monitor image number 9
Tempest GZ2711 Gaming Monitor image number 10
Tempest GZ2711 Gaming Monitor image number 11
Tempest GZ2711 Gaming Monitor image number 12
Bringing Game And Movies To Life
The Tempest GZ2711 is designed for ultimate gamer and designers by with its OLED / QHD /240Hz/ ultra high contrast specifications
THE COMPETITIVE WORK / PLAY CHOICE
The Tempest GZ2711 is designed for ultimate gamer and designers by with its OLED / QHD /240Hz/ ultra high contrast specifications that empower your work & play experience. GZ2711 comes with WOLED wide gamut technology with DCI-P3 98.5% and ultra fast response time.
GZ2711
SEARCHING FOR NEW TERRITORY
 ELEVATE YOUR VISUAL EXPERIENCE
Equipped with OLED technology, GZ2711 can provide lively and outstanding colors with Ultra-wide color gamut of DCI-P3 98.5%. Experience the brilliance of Self-lit OLED pixels, delivering the deepest blacks and vibrant colors at any brightness level. With unparalleled contrast, every detail is elevated, immersing you in the ultimate gaming or movie world.
DEEP BLACKS, VIVID COLORS: CLARITY IN EVERY SCENE
Delivers exceptionally deep blacks and vivid colors, maintaining outstanding contrast and detail clarity whether the screen is set to high or low brightness, ensuring every detail is prominent even in the darkest scenes.
PERSONALIZE YOUR PALETTE WITH PRECISION
Experience the power of tailor-made color adjustments with our 6-axis color control for RBGCMY adjustments. Dive into the nuances of saturation and hue to fine-tune a color scheme that's uniquely yours. With color gamut DCI-P3 and Adobe RGB, design the perfect visual ambiance to match your individual style and requirements.
QHD: CLARITY REDEFINED
The QHD resolution not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive.
 SMOOTH OPERATOR
SMOOTH OPERATOR
Say goodbye to screen tearing. Adopt AMD FreeSync Premium ensures fluid visuals, even during fluctuations in frame rates.
GAIN A COMPETITIVE EDGE
Enjoy lightning-fast 0.03 ms response times with an ultra-high 240Hz refresh rate and AMD FreeSync Premium, ensuring crystal-clear, seamless visuals without tearing.
LOW BLUE LIGHT & FLICKER-FREE
Protect your eyes from potentially harmful blue light with our Low Blue Light and Flicker Free technology further reducing any eye strain and allowing you to get more work or gaming done.
WIN COMFORTABLY
GZ2711 helps to deliver a smooth and comfortable working experience with hardware-controlled low blue light, delta E ≤ 2 (sRGB mode) and telescoping adjustment stand.
WIN COMFORTABLY
WIN COMFORTABLY
BUILT-IN DUAL SPEAKERS
Experience sound entertainment with 2 built-in speakers - no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
PICTURE-IN-PICTURE
 CONNECTIVITY OPTIONS
Connect your devices with I/O ports consisting of:
• HDMI2.1 x 2
• DP 1.4 x 2
• USB Type-C x 1 (PD96 W)
• USB Type-B 3.0 x 1
• USB Type-A 3.0 x 2
• 3.5 mm Audio Out x 1
사양
  • Product Number CMI-GZ2711
  • Panel Type Flat Series
  • Screen Size 27"
  • Ratio 16:9
  • Panel OLED 1.07B (10bit)
  • Resolution 2K QHD 2560x1440
  • Frame Rate 2560 x 1440 @240Hz (DP interface)
  • Contrast Ratio 1,500,000:1 (Typ.)
  • Brightness 450 cd/m2 (Max)
  • HDR HDR10
  • Color Gamut DCI-P3 98.5%
  • I/O - HDMI 2.1 2
  • I/O - DP 1.4 2
  • I/O - USB Type C 1 (PD 96W)
  • I/O - USB Type B 1
  • I/O - USB Type A 2
  • I/O - 3.5mm Audio Out 1
  • I/O - Speaker 2 (3W)
  • VRR Technology FreeSync Premium
  • Response Time 0.03ms
  • Anti-flicker Yes
  • PIP/PBP (Screen Split) Yes
  • Power Consumption 55.36W (Typ. w/ Max brightness)
  • VESA 75x75 mm
  • Tilt Adjustment -5°~+15°
  • Swivel Adjustment 15°
  • Height Adjustment 0-110 mm
  • Pivot Adjustment 0-90°
  • Product 모니터
  • Monitor Series GZ Series
  • Panel Type OLED
